20 Most Recent Jensen JER-323 Remote Control Questions & Answers
NECESITO EL CODIGO PARA MI CONTROL REMOTO JENSEN JER323 PARA UNA TV SONY
Jensen JER-323... | Answered on May 03, 2017
0092,0097,0099,038,039,033 are the codes to check with Memorex brand TVs. If you wish to get more, check these sites. http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Jensen JER-323... | Answered on Sep 27, 2013
Sony remote has no setup codes for this TV
Jensen JER-323... | Answered on Nov 09, 2012
Hello
Check out with these codes.
0093 & 0688
OK.
Jensen JER-323... | Answered on Mar 06, 2011
Configuring codes:
  1. Turn on the component that you want to set up.
  2. Hold the component key down until the green indicator light comes on. The green light should come on after approximately 3 seconds.
  3. Release the component key.
  4. If you are programming the DVD or CD device press the "action" key. The red indicator light will come on.
  5. Within thirty seconds, enter in a 4-digit code number. The component key lights will blink with an upward motion when a code has been successfully entered. In this case proceed to step #5. If the code has not been successfully entered, the componment lights will not blink. In this case return to strep #1 and start over.
  6. Test code by pressing "Power" key. If the component turns off, you've got the right code. Follow the same instructions to set up your other components. If the component doesn't turn off, return to step 2 and use the next 4-digit code listed.
Note: If none of the codes turn your component off, try the Auto Code Scan function.
Auto Code Scan:
The Auto Code Scan feature allows you to set up your components without having to enter in code numbers. The Jensen will do the work for you! (It may take a few minutes to find your code using this method.)
  2. Hold the component key down until the light comes on. The green light should come on after approximately 3 seconds.
  5. Press "0" - "9" The green light will blink as codes are sent.
  6. As soon as the remote turns your component off, press the "action" key. (You have 1 second in which to press the "action" key to save the code.) The component key lights will blink with an upward motion when a code has been successfully entered. The component is now programmed. To find that code, proceed to Code Readback.
  7. If none of the codes turn your component off, return to step 2 and start over. Thank You
Jensen JER-323... | Answered on Sep 18, 2010
Configuring codes:
1.Hold the component key down until the green indicator light comes on. The green light should come on after approximately 3 seconds.
2.Release the component key.
3.If you are programming the DVD or CD device press the "action" key. The red indicator light will come on.
4.Within thirty seconds, enter in a 4-digit code number. The component key lights will blink with an upward motion when a code has been successfully entered. In this case proceed to step #5. If the code has not been successfully entered, the componment lights will not blink. In this case return to strep #1 and start over.
5.Test code by pressing "Power" key. If the component turns off, you've got the right code. Follow the same instructions to set up your other components. If the component doesn't turn off, return to step 2 and use the next 4-digit code listed.
Auto Code Scan:
1.Turn on the component that you want to set up.
2.Hold the component key down until the light comes on. The green light should come on after approximately 3 seconds.
3.Release the component key.
4.If you are programming the DVD or CD device press the "action" key. The red indicator light will come on.
5.Press "0" - "9" The green light will blink as codes are sent.
6.As soon as the remote turns your component off, press the "action" key. The component key lights will blink with an upward motion when a code has been successfully entered. The component is now programmed.
7.If none of the codes turn your component off, return to step 2 and start over.
Thanx
Jensen JER-323... | Answered on Jul 30, 2010
I would go to manufacturer''s web site .Codes should be obtainable there
Jensen JER-323... | Answered on Feb 22, 2010
Try: 003, 054, 055, 062, 070, 148, 170, 171. GoodLuck!
Jensen JER-323... | Answered on Nov 16, 2009
fogot how to set up my remote , got codes. trying to set up Bell Express Receiver
Jensen JER-323... | Answered on Nov 13, 2009
remotefinder.rca.com just found mine!!!!
Jensen JER-323... | Answered on May 31, 2009
go to www.jensen.com and download the codes is free.
Hi I am Vortash the manual you require can be downloaded from this site http://www.safemanuals.com
Hope this is of help Regards Vortash
Sorry but to my understanding there are no universal remote codes in existence for combos. Call an electronics repair shop. Give them the make and model number of your combo. They will be able to order you a new remote for your brand and model. If it is not too old they should be able to get one for you. I got one and it was only $21.00. Well worth it cannot use half of the features without proper remote... Good Luck!
Jensen JER-323... | Answered on May 29, 2009
Televison & Video Logo
Popular Tags
48 questions posted
Top Jensen Televison & Video Experts
Jaime Hernandez
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Jensen Televison & Video
Most Popular Question
need code
  • Televison & Video
