Bunn -o-matic G1 (1 lb. Bulk Grinder) Logo
Posted on Feb 10, 2010
Coffee doesn't fall in bag (bunnomatic G1 coffee grinder)
I use the coffee grinder G1 (bunnomatic). When the grinder is running, the coffee fall outside the bag and stick to the chute. I guess there is some static electricity in it.
How can i solve this please ?
Anonymous
Level 1:
Problem Solver:
  • Contributor 18 Answers
  • Posted on Feb 10, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
18
Questions
0
Helped
11986
Points
23
Keep clicking the De-chaf lever on the right. This tamps down all the loose grounds. Static is common with coffee due to the low humidity of the grounds (even here in Hawaii) try attaching a small metal chain to the grinder case with a used coffee clip on the end of the chain to attach to the empty bag. This will help it 'ground' out the static to the case.
Bunn G9 ground coffee is spraying outwards instead of down. How do I fix this?
Bunn G9 Retail grinder usually has a large "Chaff" plate located inside the top portion of the discharge port. There is usually a handle connected to this plate to allow the last bit of grounds to fall out of the chute. It looks like a 'trap door' that swings open and close. You will need to replace it if it's missing.
* Some places use a bag clip to attach a coffee bag to the chute so all the grounds can drop into the bag. This clip (with a small metal chain attached) also helps with the static electricity.
Aloha, ukeboy57
2answers
EA6935 krups powdered coffee inside grinder and coffee grounds noncompact
You will need to pull the grinder apart & clean it out. Most likely cause of the grinder blocking up is a leak somewhere inside the machine dampening the grounds as they exit the grinder. They bind up, won't fall out and there is your blockage. You will need to find and fix the leak, there are many, many places for the leak to be, it's a job for a Krups Service Agent. I have outer housings with cutouts in them so I can run them and look inside at the same time to find those troublesome leaks.
I have a bunn coffee grinder that keeps on jamming up everytime you put coffee beans in it. I took the front part off to clean it out every time it jams,but it keeps on doing the same thing. The model bunn...
It sounds as though your grind is out of adjustment. The grinder is probably set too fine. I have not worked on a G3 grinder but I would think it is like the Bunn G2. On the front knob you will find 2 small set screws and one larger adjustment screw (in the middle of the knob)
1. Set the selector knob to finest setting (Espresso or Turkish)
2. Loosen the 2 set screws about 2 turns.
3. Activate the start switch (you must activate the "bag switch" behind the chute)
4. With the grinder running, SLOWLY turn the center screw clockwise only until you hear a very slight whirring sound (this is the burrs touching).
5. Then, back off the center screw counter-clockwise about 1/8 of a turn, shut off grinder and re-tighten the set screws.
Check the grind in the "drip" setting by running a few beans through... the grounds should be about the consistency of sand. You should get a better flow through the machine with the grind adjusted properly. You may want to check the cleanliness of the hopper in the top... I have seen these dirty enough to impede the falling of the beans to the grinder.
Also, whenever you remove (for cleaning) the 2 larger screws that hold on the front "plate", be sure to put them back in evenly... kind of like one would with a wheel on a car- Finger-tight then slightly tighten each on a little at a time (back and forth) until tight.
Hope this helps.
1helpful
2helpful
2answers
Hello. grinder won't grind
HI
Sounds like you have a blockage in you grind passage. Try removing the brew group. Then inside the machine where the brew unit was setting there is a drop chute where the coffee is dropped into the brew unit. This will be above where the brew unit was. From the left side of the drop chute pull down and back, and it will drop coffee. This will clear an opening that relieves pressure on the passage. There is a passage inside the drop chute area that goes to the grinder. Vacuum it out. It will be on the right side of the drop chute.
Once that is cleared go to the bean hopper. There are 2 knobs in the bean hopper. Turn the large knob to the largest number. You can turn the knob to a larger number any time but it has to be grinding to turn to a smaller number. Now replace everything and make your coffee. Once you have made your coffee you can turn the knob back to a number that was higher than the one you had it on, but only when the grinder is running.
Restart a bunn coffee pot after it being off for 6 months.
Hello. Hope this is what your looking for:
http://www.bunnomatic.com/pdfs/commercial/manuals/33545.0000.pdf
follow the instructions for first setting up the unit, as most, if not all the water has evaporated by now. Don't plug it in yet :)
if not you can go to www.bunnomatic.com and download the appropriate manual, there is a link on the left side of the page, click and choose your unit.
Hope that helps, and thank you.
Bun coffee maker not working.
Hello. Hope this is what your looking for, or go to Bunnomatic.com, and look up providers by state.
http://www.bunnomatic.com/pages/serviceagents/tools/ServiceAgentsReport.asp
Whole beans fall through the Grinder
You have to remove the coffee bean hopper, there are two screws on it. Below it is the grinder and there must be a rubber seal between them. Perhaps it is crooked or broken, and then the coffee beans pass and fall down.
Top Bunn Coffee Makers & Espresso Machines Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
