20 Most Recent
Gaggia Syncrony Espresso Machine Questions & Answers
Sujet : NEED SPARE PARTS ON GAGGIA SYNCRONY DIGITAL COFFEE MAKER
Dear, Please visit parts guru website. You will get part diagram also and price also.all Gaggia machine spare parts available there.if you want order from uk. Please visit
https://www.mrbean2cup.co.uk/services/gaggia-saeco-spare-parts.php
Thanks
Shrikant Shinde
India
Hello. grinder won't grind
HI
Sounds like you have a blockage in you grind passage. Try removing the brew group. Then inside the machine where the brew unit was setting there is a drop chute where the coffee is dropped into the brew unit. This will be above where the brew unit was. From the left side of the drop chute pull down and back, and it will drop coffee. This will clear an opening that relieves pressure on the passage. There is a passage inside the drop chute area that goes to the grinder. Vacuum it out. It will be on the right side of the drop chute.
Once that is cleared go to the bean hopper. There are 2 knobs in the bean hopper. Turn the large knob to the largest number. You can turn the knob to a larger number any time but it has to be grinding to turn to a smaller number. Now replace everything and make your coffee. Once you have made your coffee you can turn the knob back to a number that was higher than the one you had it on, but only when the grinder is running.
