Is your machine a FAV6800A or FAV9800A?
Can you confirm the Model Number and the first two digits Serial Number?
Does water flow into the machine with the 120VAC power plug pulled from the machine?
If it does you have a stuck water valve.
If it doesn’t you could have a stuck pressure switch and I can walk you thru how to check in diag mode for that condition.
I know you are frustrated but with some basic troubleshooting we can determine if the issue is a stuck open
Water Inlet Valve or a defective
Pressure Switch.
Because this board doesn’t ask for the Model Number or Serial Number we need to start there.
Here is where the Model and Serial number info is located on the back of your machine.
