IF U HAVE deleted the sound card drivers from ur system two ways 1. REINSTALL THE motherboard chipset drivers cd that u got when u purchased the PC.... it will surely resolve the problem 100% OR
I WOULD RECOMMEND to install mother chipset driver CD available to u If u dont have it then goto the above link and match which hardware u have in ur system for sound card and install the selective sofware... Take care and best of luck Waiting for ur reply
Using Shift+Delete to remove files/folders bypasses the recycle bin which is your normal means of recovering accidentally deleted files. You can go to download.com and search for file recovery programs. Some are available that will search your hard drive and can maybe recover what you lost. It is important to do so as quickly as possible because once files are permanently deleted on the hard drive, the sectors that they occupied are no longer protected and can be overwritten by any program or file.
have you lost your photos on your memory card/USB drive?
If you appear to be a Mac user, just try this Photo Recovery app. It can nimbly recover deleted photo files, music sources and video clips from Mac hard disk drive and memory devices containing USB Drive and SD card. http://www.leawo.org/photo-recovery-mac/
Simply insert the card to your Mac and run the photo recovery app. The software may help you scan the card and then show you files it has found. Choose the pics you want to get back and hit the "Recover" button to start.
It certainly sounds as if you've lost system files Without knowing your OS it's hard to tell you which way to go. If you can get access to your own files, the ones you want to keep. Back then up onto a different drive or external drive and then completely reformat and start from scratch. A bit of a hassle but that's the cost of accidentally deleting files. Without knowing what you deleted it would be quicker to reformat. Plus you end up with a nice clean and usually faster computer.
If by chance you run Vista you can replace lost or damaged system files by popping in your Vista DVD and follow the prompts.
you need to go to Control Panel - system - Device Manager. There you will be able to find the drive that runs your 'sound card device'. click on that and it should indicate if this device is working properly or not and have a button to click on for fixing. If that doesnt work, try another simple route and if your computer has this setting....go to 'system restore point' and set it back a few days, or a week. check for sound, then carefully recheck the old files you want to delete. Double check the file you want to delete for it may support your sound card and may not work without certain programs. Hope this helped!!!
Yes. Once we restore the computer is set back to factory settings all the functionalities along with sound and cd/dvd drive will work fine as the software,drivers along with saved data and corrupted files will be deleted and a fresh copy of windows will be installed.
In order to perform a restore back to factory settings follow the steps below:
1. Turn off the computer completely.
2. Make sure the computer is connected to power adapter.
3. Press the power button to turn it back on and at the same time simultaneously keep tapping the ' F11 ' key on the keypad until you see a screen says 'welcome to hp recovery manager ' . you may here few beep sounds during this process. Select ' destructive recovery' option and follow the onscreen instructions to complete the process.
Note: This process may take an hour to complete and make sure to take a back up of your important data on to a cd or dvd as the process completely deletes all the files on the computer.
