Computers & Internet Logo
Posted on Feb 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HOW DO I USE THE MEMORY STICK? - Sony 512MB Micro Vault Ultra Mini USB 2.0 Flash Drive 512 MB USB Portable (USM512DVFT) Drive
Anonymous
Level 2:
Sniper:
  • Expert 68 Answers
  • Posted on Feb 02, 2010
Anonymous
Expert
Level 2:
Sniper:
Answers
68
Questions
0
Helped
19476
Points
254
Memory sticks are plug and play devices.
simply plug in the stick on the usb port and the device would get automatically detected. it would be visible in the my computer window.
you can use it for storing your data.
Anonymous
Level 3:
President:
  • Master 1,185 Answers
Anonymous
Master
Level 3:
President:
Answers
1185
Questions
Helped
385966
Points
3708
Plug it into a USB port on your PC or laptop
The machine should recognise it as a USB device and assign it a drive letter.
You then have a choice of opening the device from explorer or it may try to self open via XP
1helpful
What memory sticks do i need
Quoted from the technical specifications available on the Sony website UK. http://www.sony.co.uk/electronics/cyber-shot-compact-cameras/dsc-h300/specifications Storage Media Internal MemoryApprox.55MB Compatible Recording MediaMemory Stick Duo, Memory Stick PRO Duo, Memory Stick PRO Duo (High Speed), Memory Stick PROHG Duo, Memory Stick Micro*10 , Memory Stick Micro (Mark2)*10 , Memory Stick XC-HG Duo, SD Memory Card, SDHC Memory Card, SDXC Memory Card, microSD Memory Card*10 , microSDHC Memory Card*10 , microSDXC Memory Card*10
tip
Sony Memory Stick Formatter Software If your Sony Memory Stick has stopped...
If your Sony Memory Stick has stopped working in your digital device,
Sony's Memory Stick Formatter Software may be able to format your Memory Stick in a more compatible way for your device.
Compatible operating systems include:
* Windows® 7 Starter / Home Basic / Home Premium / Professional / Enterprise / Ultimate
* Windows Vista® Home Basic / Home Premium / Business / Ultimate
* Windows® XP Home Edition / Professional
* Windows® 2000 Professional
Preparation
* Confirm that the write-protection switch of the Memory Stick is set to the "Write enable" position.
* Insert the Memory Stick into the Memory Stick slot of the device or computer.
* If you are using a file recorded on Memory Stick with another application, quit the application before beginning the formatting process.
The Format Process
Note: Formatting will erase all files in the Memory Stick. Always double-check the Memory Stick contents before formatting to prevent loss of important data.
* To start Memory Stick Formatter, click Start->Programs->Memory Stick Utility->Memory Stick Formatter.
* At the "Drive List" screen, click to highlight the drive letter that represents the Memory Stick device/slot.
* Click the Start Format button.
* At the "Warning..." screen, confirm that you wish to format the Memory Stick, and click OK. Note: To quit the process, click the Cancel button.
* Do not remove the Memory Stick from the Memory Stick slot during formatting, as this may cause corruption.
* At the "Format was successful" message, click OK.
* To quit the Memory Stick formatter utility, click the Exit button.
Download the Sony Memory Stick Formatter Here.
I hope that helps.
____________________________________
Click here for Sony's Memory Card File Rescue software.
tip
Preparation
The Format Process
I hope that helps.
Camera keeps telling me to reinsert the memory card. I've tried to new cards. When I put the memory card I was replacing because it is full, it goes back into the camera just fine.
As a last resort you could copy the full card to a computer and then delete the pictures on the card and use that again.
Here is the error list from the camera manual.
This is all I can suggest from here.
"Reinsert the Memory Stick Error"
Insert the "Memory Stick Duo" correctly.
The inserted "Memory Stick Duo"cannot be used in your camera
(See below).
The "Memory Stick Duo" is damaged.
The terminal section of the "Memory Stick Duo" is dirty
Compatible cards.
Memory Stick Duo (without MagicGate)
Memory Stick Duo (with MagicGate) *1 *2
MagicGate Memory Stick Duo *1
Memory Stick PRO Duo *1 *2
NOT compatible
Memory Stick (without MagicGate)
Memory Stick (with MagicGate)
Memory Stick PRO
Some Memory Stick Duo have a write protect switch on the back.
You cannot record, edit or delete images if you
slide the write-protect switch to LOCK with a
fine-tipped object
*1
"Memory Stick Duo", "MagicGate Memory
Stick Duo" and "Memory Stick PRO Duo" are
equipped with MagicGate functions.
MagicGate is copyright protection technology
that uses encryption technology. Data
recording/playback th
at requires MagicGate
functions cannot be performed with this
camera.
*2
Supports high-speed data transfer using a
parallel interface.
Hi..my dell xps M1210 can not read the memory stick pro duo 2 gb what can I do ? can you hel me please..?
Hi! Welcome to FixYa!
Memory Sticks has many types, Memory Stick duo, Memory Stick Pro Duo. Memory stick duo is basically the first generation Memory stick and in terms of capacity and speed, it is slower and low in capacity. Memory stick Pro Duo is faster and capacity is larger, speed is faster..
For your issue, the XPS M1210 can only support Memory Stick Duo since it is quite an older machine and during that time, memory stick duo has just released. Have you tried other memory sticks for you to isolate the issue?
You have 2 options for this, first, try contacting Dell and ask for updated firmware for your memory card reader and other option is to use a USB memory stick pro reader that supports your memory card. Hope this helps.
tip
Preparation
The Format Process
I hope that helps.
tip
Preparation
The Format Process
I hope that helps.
I bought a new Memory stick for my Sony DCR-TRV320 Camcorder and when i switch my device to memory mode, it tells me "Memory Stick Error."
Check the following:
Memory Stick is inserted in correct position and orientation in camcorder. Try re-inserting several times.
Write-protect tab is switched to allow writing to memory stick (on back of memory stick)
Memory Stick is formatted in FAT file system (this should already be done except if memory stick has been formatted in a computer in a different format)
Memory Stick is not over the maximum capacity memory stick of the camcorder.
Memory Stick is not full.
Memory Stick is clean and dry.
The dcr-trv320 is a 2000 yr. model and came with a 4mb capacity stick and can probably only use up to a 128mb capacity stick or possibly 256mb. Most memory sticks you can buy today are 1GB, 4GB, 8GB etc. memory stick pro duo. and are probably incompatible. E-Bay has some of the old memory sticks like the 128mb for sale.
There is a slight possibility that static electricity discharge zapped the stick. Try another memory stick or try the stick in another device.
What tyue of memory stick do you need for a eclipse head unit and does it need to be formatted to play mp3
Memory Stick Playback Features
Compatibility: The AVN5495 can only play music data recorded in ATRAC 3 on MagicGate Memory Sticks (white). MagicGate Memory Sticks and standard Memory Sticks can also be used for database updates and ESN. Memory Stick Duo must always be used with the Memory Stick Duo adapter. Memory Sticks with a capacity of up to 128MB are supported. Memory Stick PRO is not supported.
3helpful
Memory stick for Sony Mavica FD92
Most older digital cameras do not work when you try to use a memory stick adapter and the newer, smaller size memory sticks. Because this memory format is so old that it is no longer sold in retail stores, your best option is to buy a memory stick online. You can find these memory sticks on eBay.
To find more eBay auctions for these memory sticks, go to the Memory Cards category on eBay. Then, on the left side select Format = Memory Stick, and Storage Capacity = 64MB and under.
In the resulting search, only look at the auctions that are actually for 64MB and under Memory Sticks - you will find a lot of mis-classified memory in the search results - items that are the wrong format (not memory sticks) or too large to work in your camera.
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
