1990 Honda Accord Logo
Anonymous Posted on Feb 01, 2010
Cooling fan continues to run too long with engine off.
1990 Honda Accord. When I turn off the engine in cold weather the cooling fan continues to run until the battery dies.????? (if I let it.)
Anonymous
Level 1:
Champion:
  • Contributor 435 Answers
  • Posted on Feb 02, 2010
Anonymous
Contributor
Level 1:
Champion:
Answers
435
Questions
0
Helped
138339
Points
44
The thermostat switch need to be check and change.
Testimonial: "Excellent Solution! My frustration is cured. This has annoyed me for two winters. One previous attempt produced no result. Thank you. "
How you know if you need a cooling fan relay
If your cooling fan is running all the time or if the cooling fan does not turn on when engine temperature is at normal or higher than normal temperature. It is possible in cold weather the fan may not turn on often.
2helpful
Cooling fan runs with car turned off, 1990 honda accord
Find the cooling fan relay,it is stuck,just replace it to solve this problem,thank you,and please rate.
2answers
1991 honda accord lx cooling fan
Some vehicles have sensors that can control the electric fan with the ignition off to keep the heat buildup that naturally occurs right after turning off the engine. This can prevent hard starting that can happen with a hot engine. If it is doing this an abnormal amount, the sensor that is operable with the ignition off may be failing. Before turning off the ignition, check to see if the engine temperature is pushing the 'red zone;' if it is, then the fan operation may be normal but your engine may be running hot.
Cooling runs with engine cold
check the relay swithes it looks like one of them is going out
Engine overheats. plus once engine running a green flashing light with a (s) on it.
#1. Check coolant level,(engine stone cold and not running) change to a new one if not done in last 2 years.
#2. Change thermostat to a new one, Honda thermostat only, also every 2 years.
#3. In the thermostat housing there is a "coolant switch A" you should have a plug going to it, unplug it and while your engine is running almost at operating temp, bridge 2 wires with a wire, your cooling fan/fans should come on, also check for continuity you should have no continuity when engine is cold and continuity when the engine is at operating temp.
#4. If there is no continuity when engine is at operating temp then you need a new "coolant switch A"
Let me know here, if you need more help.
Fan continues to run while car is off
Usually on most vehicles the coolant temperature sensor sends info to the ecm which then determines when to turn your fan on and off, when you turn the car off the fan may continue to run until the engine reaches a cooler temperature, if the front radiator grill is'nt getting proper air flow to cool the coolant down check the radiator grill for damage or debris build up, if the car has problems over heating check the entire cooling system.
2helpful
2answers
88 Cadillac Deville cooling fan runs continuously
you have a bad fan swtich in the block or the therostat housing its an easy fix
2answers
Radiator Cooling Fan
perfectly normal its due to the warmer weather tempratures
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
