Viking VSM700 Stand Mixer Logo
Posted on Feb 18, 2008
Viking stand mixer dough hook will not come off
I can not get the dough hook off my viking stand mixer, has anyone else had this problem, how did you remove the hook from the mixer?
  • Anonymous Nov 25, 2008
    Yes I have had the problem, You have to push up and turn at the same time. It doesnt feel right and it fights you a little bit but it does work. ITs not a very user friendly mixer
A
Anonymous
Had the same problem with dough hook not coming off. Sent to a Viking dealer in Rockford and was quoted $600. to replace gear box. Took it back without repairs and call Viking listed in manual and sent it to them on a Monday and by Friday had it back fixed and no charge.DM
How do i insert dough hooks into stand mixer professional 600??? There are no holes.
Your Flat Beater, Wire Whip and Dough Hook attachement ends should
look the same. They are inserted onto the beater shaft and held in place
by a single pin. The reason you cannot attach the dough hook to the
beater shaft because it is the wrong hook for your particular model.
Need to know the part number for a dough hook for a hobart a200c stand mixer. What number would be stamped on the hook?
A 20 qt "E" dough arm is S-23467. A 12 qt is S-62886.
A 20 qt "S" sweet dough beater is R-8022.
1helpful
Dough mixing paddle will not stay in my wife's Viking mixer
pour a little wesson oil into the attachment holes and work the release while inserting and removing the attachment. Make sure the unit is unpluged. The oil will lubricate the lock mechanism.
The dough hook is stuck in the beater shaft of kitchenaid mixer
It sounds like it got overloaded when you last mixed dough. It will only come off the way it went on. If it has been bent on, it may need a bit of gentle encouragement.
Used the bread kneading hook, after 10 minutes, smoking
The mixer motor has probably overheated, as proper use and care was not being followed with the stand mixer.
Bread doughs are recommended to be mixed on speed 2 only and never for longer than 7 minutes. With the resistance of a bread dough that is provided against the beater, mixing for over 7 minutes may overheat mixer and cause smoking.
Please consult your use and care guide to refresh your memory about how to properly use your mixer for making bread doughs.
2helpful
Bread dough hook slips when mixing
This is not a solution but I think you have a serious problem you might have sheared some gear teeth whent the mixer jammed and it only manifests itself under a heavy load, I would take it to a repair guy, those mixers are expensive and it would be worth it.
I need replacement beaters for a dough hook stand mixer
Information from manufacturer stating replacement parts have been exhausted.
Jan 30, 2009 • Food Mixers
Motor Dead
I had the same problem the first time I tried to make a small batch of bagel dough (very small!) I had to send it back for repair and wait.....sorry that the news is not better.
Dough Hook Stops moveing under heavy load
Does the mixer work in any other speeds?Are you mixing pizza dough and in what speed?I service these mixers alot--i work for hobart.It sounds to me like you have a sheared key on one of the shafts.The mixer doesnt have a clutch.
Top Viking Food Mixers Experts
ADMIN Andrew
ADMIN Andrew
john h
ADMIN Eric
ADMIN Eric
Are you a Viking Food Mixer Expert? Answer questions, earn points and help others
