Even i try many times still no output been printout ,how can i ]
solve this problem help
No print out?, you must replace your main board, the IC in printing may be damage it should be replace.
SOURCE: My Epson Stylus R230 has both red lights blinking
i have one message from Epson photo R230 " service required" and both the red lights are blinking
SOURCE: EPSON Stylus Photo R230 Series - Driver Download
Hi dear, you can download your required driver free from the following links;
http://www.epson.com.sg/epson/drivers/driver_download.htm?dc=1&mode=3&m=false&catid=1&pid=950
http://www.epson.com.sg/epson/drivers/driver_download.htm?mode=2&productModel=1
http://driverzone.com/device.php?id=12567
Good Luck
SOURCE: Epson Stylus R230 Light Magenta Not working
Print first a nozzle check pattern, self test which they say. Check your manual for your printer, it should be accessible from that if you dont have any manual, go to the epson website and download a manual. Usually the self test would go like this.
While the printer is turned off, you press and hold down the paper feed button, continue holding it down while turning on the printer. It will print the nozzle check pattern standalone. If you see all the colors then the issue your having is a color management issue, if you do not see the cyan, magenta, yellow, black, light magenta and light cyan from that test; then you will need to do 3 consecutive times of Head Cleaning from the maintenance program in your computer. If you have a windows xp it goes like this.
Click on start go to control panel - printers and faxes -
you right click on your printer icon and select printing prefrences. From there, go to maintenance tab and click head cleaning, go through that cycle 3 consecutive times and see if it improved. Good luck....
SOURCE: how to install EPSON Stylus Photo R230 without cd
You can install the printer by downloading the software from this link.
