Insignia IS-LCDTV32 32 in. Television Logo
Posted on Feb 14, 2008
INSIGNIA FLAT SCREE HDTV
6 months ago I purchased an Insignia Flat screen HDTV. I recently noticed a verticle line seemingly burned in at the 3" "non hdtv"side bar. It is under the original 12 month warranty with an extended warranty from Best Buy. Can this be repaired or does it need to be replaced? i dont want any "bs" when I call them. I have in home service. I dont want to "lose" use of tv while it is shipped for repair, only to find out it has to be replaced. Tech lingo would be helpfull.Thanks
Anonymous
Level 1:
  • Contributor 31 Answers
  • Posted on Feb 21, 2008
Anonymous
Contributor
Level 1:
Answers
31
Questions
0
Helped
20433
Points
63
Best thing you can do is call 888-Best-Buy and schedule a service call. I wish i could tell you if it would be a repair or replace situation, but that will greatly depend on the part availability for your TV.
Insignia parts are often very hard to find (only 2 or 3 parts vendors in the US) so the sooner you call the better your chances of a quick repair.
Insignia 32 flat screen will not stay on. Power on and go right back out? What is the cause for this to happen?
Top 144 Complaints and Reviews about Insignia TV
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.5 - ‎80 votes My son purchased a 42" Insignia TV for me before he died. ... Bought 50 inch Insigniaand after 13 months screen starts going black but sound stays on. ... I was having problems with the Netflix app on my 42" Insignia smart TV, so I took the ...
Insignia 42 tv horizontal line problems
One among the back-light CCFL lamp has burned out. Replace it.
We received a second hand 32" insignia about 2
The display panel is bad and to expensive to fix. You can check the board at the top . This is the T con board . Be sure that the flat cables ans pluggin good.
1helpful
2 horizontal lines which scroll
Place a 2 to 3 prong AC adapter on the power cord. It will isolate the ground and should fix your problem.
I hope this was helpful, best wishes.
4helpful
2answers
Purchased a 42-Screen "flickers"
Inverter Board going bad or loose plug, then the backlight board will fail within 3-4 weeks later. Good thing you saved a few hundred on the x-warranty, BB won't do a damned thing for you regardless; it's discontinued & they lie about their 'replacement vouchers'.
A 12" bi-metal blade is recommended for your reciprocating saw so that you can cut this thing into small enough pieces for your trash collection.
3helpful
3answers
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
2answers
Insignia 42" black screen and line problem
Insignia and Geek squad has no other solution exvcept 1080i
Insignia(samsung) 50" plasma Vertical red lines
I would take it back. I know from purchasing an Insignia LCD from them a while back, the TV just died after about 4 or 5 months. They ended up offering me another TV or with store credit. I took the store credit and chose another TV. I also did not have a warranty. I was told since it was Insignia (which is a Best Buy house brand) that replacing it was not a problem. Good luck.
Top Insignia Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
