I am not familiar with this camera. I have been reading the manual and after getting it set up I have been trying to take pics. When I press the shutter it doesn't make a click sound to let me know that a photo has been taken. What could be the problem?
I loaded it according to the instruction manual. It is when I press the button to take a picture. The button doesn't seem to be working.I loaded it according to the instruction manual. It is when I press the button to take a picture. The button doesn't seem to be working.
You can't post conmments that contain an email address.
First, make sure you've got a good set of batteries installed. The camera uses two LR-44 alkaline or G13 silver-oxide batteries.
Did you load film? If so, how did you get it loaded with the inoperable shutter? If the problem is happening while loading film, make sure you follow the instructions and set the mode dial to 125X.
If it's not the easy stuff, it's got to be the hard stuff. Since this isn't a new camera by any shot, the lubricants may have dried out or the mechanical parts may have worn out. Take the camera in to a reputable camera shop and request a CLA (Clean-Lubricate-Adjust), the camera equivalent of an automobilie tune-up.
So the shutter works while loading the film and advancing to the first frame?So the shutter works while loading the film and advancing to the first frame?
For a start, what particular camera do you have, and do you have the instruction manual ? A read through that may well help. If you have no manual, look up the camera make and model on Google, and there may be a link to a manual which you can download in PDF format, to read on your computer.
Briefly, you point the camera at the subject you wish to photograph, switch it on, frame it in the viewfinder (or, these days, on the LCD screen) and press the shutter release. Depending on the sophistication of your equipment, you may have the facility to adjust the shutter speed, lens aperture etc, but until you are more familiar with it I should set ISO 200, auto White Balance, and leave everything else on auto settings. You should get acceptable results at least 90% of the time.
Hello Eero,
The shutter speed must be set very high to
"stop" or freeze the action of movement.. You should have a shutter speed priority program that lets you choose the shutter speed and the camera does the rest.... read your owners manual...
The pictures are blurry due to camera shake, which in itself is caused by the slow shutter speed. Try using shake reduction setting. To increase the shutter speed, raise the ISO rating.
Not sure what you are really asking here as it would depend on the settings you have selected to use.
For instance if your ISO ) ASA film speed) is set to 64 and you have an aperture priority setting of say 6 then the shutter will go clllllllllickkkkk ( be slow say 1/30th of a second. As opposed to say ISO of 200 and an aperture of 16 the camera will go cliick now if you select ISO 400 and aperture of 16 the camera will clk This is the "sports type setting for fast moving objects ) I am presuming daylight average light for the above after 4pm or in some shade areas shutter speed can also be delayed and the picture result is blurred due to camera shake at low speeds. then u need a tripod
Now what have you selected as an amateur snapshot artist? Day night settings AUTO ISO 100 + ........ portratit landscape night
Any of these settings on auto will also be delayed depending on ISO and the amount of ambiant light available to the camera. So you need to get to know your cameraq by practice
Some settings ( see manual) suggest using shutter priority to get good pics Others suggest aperture priority.
It might be better for you to get a basic digital photography book to help you understand and compose good pics ( Digital photography for dummies ( or DP basics)
Hers a tip worth remembering with apertures
Smaller the number larger the hole(aperture) Larger the number smaller the aperture
larger hole for lower light smaller hole for very bright light
so experiment with aperture to be familiar on what to select for the degree of light then test different ISO speeds and keep notes.
When you use zoom increase the EV by 1+ and see what the difference is to standard distance
All great fun and learning and now cheaper because you dont have to pay for film or development to see what creative pics you have made!
So perhaps the camera does not have a problem, it just has you, and
you need to bond so Good Luck and ,many happy snappy hours of fun
You are massively overexposing the picture. Manual mode means you have to set the exposure manually. You need to adjust the settings so that the light meter reads somewhere around the zero mark.
M mode is most useful for flash photography where you want a certain level of ambient illumination in the picture as well.
If you want some control over the camera but don't want to worry about exposure too much, use A and S modes. The manual will explain all of these modes.
What you are experiencing is not blur, its camera shake. You are shooting in low light so the shutter speed is being reduced by the camera's automatic features. Also the longer the lens (the farther you zoom), the higher the shutter speed you need. Even for non moving objects or when panning the shutter speed should be at least one stop above the focal length. ie - 300mm lens = 500 or 1000 shutter AT LEAST! (and don't forget, if its a film lens on your rebel, thats actually
300mm x 1.6 =480mm, so 1000 shutter or higher min.) Moving objects require even faster shutters. Solutions: Get faster (also called brighter) lenses which can be pricey. In low light use higher iso settings in the camera menu. Shoot in either manual or Tv mode and choose the higher shutter speeds while using the light meter to decide aperture. Use wider angle lenses or back off the zoom and move closer. Stabilizers built into the lens can steady the shot by two to four times as well.
