Pentax Espio 105S 35mm Film Camera Logo
Posted on Sep 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pentax ESPIO738G Error code H1 H2
When I switch on the lens opens but will not zoom.
If I try to take a photo and I just get a clicking noise, when I try to switch off I get error code H1 or occasionally H2.
I can only switch off and close the lens by using the mid roll rewind.
I have fitted a new battery just in case but it made no difference.
Thanks for any info
Tony Butterfield
Anonymous
Level 3:
  • Master 6,831 Answers
  • Posted on Nov 22, 2010
Anonymous
Master
Level 3:
Answers
6831
Questions
0
Helped
1213810
Points
16134
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
ASKO TL751 error messages ?
Asko dryers as model T760 or T780 indicate failure by error message (like "Overflow", "Sensor", "Thermistor", ...) while the model TL751 indicate failure by error code ("H1", "H2", ...)
Below you can see a list of error codes:
H1 error - Humidity sensor error
H2 error - Drying temperature sensor open/short error
H5 error - Heater overheated (ELECTRIC TYPE)
Heater disconnection check and H4/H6 error (ELECTRIC TYPE)
H3 Error - Flame Detector Open Defect (Gas Type)
H7 Error - Gas Valve Defect or Gas Blocked-off (Gas Type)
H8 Error - Igniter Defect or Flame Detector Short (Gas Type)
Dado
Error H1 and H2
this error happen when the temperature increase 7c or more in 1 minutes o by 2c in 2 minutes
Turn OFF the machine for clear and turn ON again.
God bless you
On the lcd it shows "E" "E 9" and I do not know what this means and the camera will not work. What needs to be done
This question has been answered repeatedly. Pentax error codes are mostly for camera repair technician diagnosis and most of the time mean the camera is broken and needs professional servicing. Some Pentax Error Codes:
E: "E" often indicates a film jam. This code can appear when the film is inserted incorrectly, when the batteries are changed in the middle of a roll of film, if you are using defective film, etc. If "E" appears in your camera's information display, try to rewind your film manually (see your user's guide for instructions on how to activate your mid-roll rewind function), and try a different roll. If this problem keeps occurring, you might need to send the camera to us for repair.
E3, E7, E37: These codes often signal a problem with your shutter mechanism.
E9, E93-E97: These codes may indicate a problem with your zoom lens.
H0-H9: These H codes can also identify a problem with your camera's shutter.
U1-U9: These U codes may also indicate a problem with your camera's zoom lens.
These codes are standard for both Digital and film cameras.
Please rate our helpfulness to keep the service viable++++Thanks for using FIXYA
3helpful
AV error whn pentax ist DL & Quantaray zoom lens attached
I've got the same problem. The problem is that the lense is loosely attached to the body. What you need to do is that when you see the Av flashing, press the lense of the camera to the body and twist the lense to the left a bit. This tightens the connection. You can then take the photo.
Zoom lens prevents me taking a photo
changed the auto aperture under custom settings to permit and that was it
2helpful
Lens error 0x2117 in Pentax optio E50
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
2answers
Pentax Optio S6 re-occuring problem
Greetings...
Here is the information on the lens system for the Pentax...
The Sliding Lens system is a proprietary PENTAX lens system that offsets the central lens groups from the optical lens axis and retracts the lens in two steps in the cylinder for minimized overall body depth.
I think from what you have stated, the lens system is off track, hense the noise and the blurry image...
Hope this is helpful...
Ed
2helpful
2answers
What does HI or H1 mean?
This is a zoom error code - the flexible circuit going to the shutter in the barrel is probably worn out. It'll have to go to a repair shop.
Top Pentax Photography Experts
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
