The pump out motor is inline with the outlet pipe and can be checked by a)Looking to see if it the motor spins while in the pump out mode. b) Test with AC voltmeter across the 2 terminals for voltage while in pump out mode.
The motor can be removed by removing the 2 hose clips and disconnecting the electrical push on lugs.
If voltage is across the terminals and motor does not spin...indicates that the motor is open circuit and must be replaced.
Make sure outlet pipe is not blocked or obstructed.
