Candy CN146 Front Load Washer Logo
Posted on Mar 30, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Candy washer dryer filling water dry cycle then empty
My candy washer dryer filling water dry cycle then empty but only on dry cycle when finish washe program and start to dry cycle water fill from intel valve and non stop filling and empty finel dryer stop clothes wet
Anonymous
Level 3:
  • Master 1,010 Answers
  • Posted on Mar 31, 2013
Anonymous
Master
Level 3:
Answers
1010
Questions
Helped
247150
Points
3078
Could be the circuit board at fault
5 Related Answers
Anonymous
  • 716 Answers
  • Posted on Feb 04, 2009
SOURCE: condenser dryer gets hot but cloths not drying and water drainer
Check The Ducting To Make Sure There Is No Obstructions Inside. Find The Outlet Outside Where The Duct Goes And See If Your Getting A lot Of Air. In Some Cases You May Have To Remove The Back Of The Dryer To Remove The Biggest Lint Ball In The World.
This Huge Lint Ball Builds Up Over Time And Quickly For Users Who Do Not Clean The Lint Trap On Every Cycle.
All Of The Above Will Cause The Dryer To Not Be Able To Get Good Air Flow Thus Causing The Machine To Have To Much Back Pressure.
Anonymous
  • 903 Answers
  • Posted on Oct 30, 2008
SOURCE: Candy Model CE10 won't spin
It sound like the carbon brushes in the motor may need changing. It sohuld still be okay to get repaired, as most machines have generic brushes for all of thier models. It's worth calling an engineer and suggesting that the brushes have gone in the motor to get a quote on the repair job. Some engineers will come out and give you a free quote anyway.
macdara dunne
  • 46 Answers
  • Posted on Feb 07, 2008
SOURCE: CNW136 Dryer not working !!
lift the lid with the power off and reset the safety stat. look for a and little red button on the metal heater duct on the top of the machine
Anonymous
  • Posted on Oct 26, 2009
SOURCE: my candy 514 is not draining properly - even after
I have a GE and my friend has the same problem with his whirlpool. Removed the frt cover adn looking at the washer on the left side there is a clean out drain. My kids leave things in pockets and filles this drain up and washer will not drain. it is very easy to do
Testimonial: "The drain thing was definitely clogged! Have cleared it and am mopping the mess up - will know if its worked in about 15 mins.."
Anonymous
  • Posted on Mar 11, 2010
SOURCE: Candy CMD146 Washer/Dryer
CANDY CMD 146
when spinning the drum shakes badly and smoke comes out from soap draw , both shocks are intact at bottom and both springs look ok at each side, i dont know what else to look for please help
1helpful
Washer will only fill slightly on rinse cycle and not at all on wash cycle
Is the water on? Does the pump run when emptying machine? If yes to both, try running the machine through a spin cycle if you can and let it finish on its own. The valve should close and allow it to fill. Also, top or front load washer? ... These may help How to Fix Washing Machine That Won Fill With Water DoItYourself com
How do you cancel wash cycle on candy do df 800 the programme is stuck on filling up so have turned water supply off but cannot cancel programme
Good evening Julie
you have problems with your Candy, so have I with mine.it is mostly when I am starting a drying program, that she starts washing again. Then I :
  • turn the machine off
  • Wait 3-5 minutes
  • Turn on emptying
  • Wait 3-5 minutes
  • Turn on spinning
  • Wait 3-5 minutes
Try this way, turning the machine off, waiting and over to the programme you want.
good luck
kolbrun
I am having 2 issues. Most importantly, my front load washer/dryer is skipping drying time. I typically wash the clothes then put dryer sheets in and use the dry only on low heat option. It starts...
Your two issues may be related. A combo washer / dryer uses a fine spray of cool water to condense moisture out of the air stream while drying. This water is then pumped down the drain. Cold water is also used to fill the softner dispenser. If the inlet screen on the cold water connection to the machine is restricted, those are two of several things which could show up. Turn cold water valve supplying water to machine off. Unscrew cold water fill hose from machine. Remove screen from inside machine, clean, re-install, re-attach cold water fill hose, turn cold water valve back on and see if performace improved.
I have a candy ciw 100t washer dryer and the water never gets hot, is this a cold fill washing machine?
to find if this is a cold fill machine only, just check the back and see how many hoses are fitted to it.I would assume it is cold fill and the problem is within the heater.
Whirlpool top loading washing machine not finishing cycle
SOUNDS LIKE A PUMP HAS GONE BAD. REPLACE IT. IT WOULDN'T COST TOO MUCH.
Water consumption query
put the outlet hose into a big bucket with mesurment on it :-)
if it over fills tun of the washing machine
empty the bucket
and continue cycle
5helpful
2answers
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
1helpful
Drum is filling with water after each wash
There is only 2 possibilities for the drum to fill with water after it has finished.
Firstly, if the empty pipe is connected to the sink outlet pipe, the water can syphon back into the washer if the pipe is too low, thereby slowly filling the washer when not in use.
Solution is to lift the outlet pipe higher.than the bottom of the sink.
The other reason is the inlet valve is not shutting off properly.
To prove if this is the case, turn the water off at the valve, if it is hot and cold fill, then turn the hot off only, and wait and see if water comes in over a period of time, if it does not then you need to replace the hot valve.
If water stills comes in with hot turned off, then you need to replace the cold valve.
If cold fill only , turn off cold and wait to see if any water comes in, if it does not, then replace cold valve.
Plz rate my solution.
Thanks.
2answers
1helpful
2answers
Hotpoint ultima 1200 washer/dryer
Have suffered the same problem. Suggest you remove back (after turning off electrical supply) and look at the water outlet pipe - you may have a sock or two in this - remember to reattach outlet and secure in position.
Top Candy Washing Machines Experts
Kolbrun...
Oliver Street
ADMIN Andrew
ADMIN Andrew
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
