Dell Dimension 2400 PC Desktop Logo
Posted on Jan 12, 2010
Im trying to install windows vista but its not leting me its saying "this computers hardware may not support botting to this disk ensure that the disl controller is enabled in the computer bios menu"
Scott McLean
Level 1:
Problem Solver:
  • Contributor 18 Answers
  • Posted on Jan 12, 2010
Scott McLean
Contributor
Level 1:
Problem Solver:
Answers
18
Questions
Helped
17751
Points
59
To resolve this problem, follow these steps:
  1. Create one or more partitions on all the hard disks that are not initialized.
  2. Restart the computer.
  3. Install Windows Vista.
Microsoft Support Link to article
1helpful
Im trying to load windows 7 on a 2Tb h/drive, i get error windows cannot be installed to diskshow details the selected partion requires 5723 mb space.
need to go into advanced on setup (on screen says install its bottom left of the screen) and go to format drive and delete other file partitions. then install.
Samsung r530 laptop hard disk warning
Error message when you try to install Windows Vista on computer that has...
This problem occurs because Windows Vista cannot distinguish between ambiguous hard disks.
In versions of Microsoft Windows Setup that are earlier than Windows Vista Setup, hard disks are marked with distinct values to distinguish them. However, this method of distinguishing hard disks is no longer supported because of the potential for data corruption on hard disks.
Do you have more than one hard drive connected to your computer?
If you have two hard drives, remove the second hard drive and continue with the installation.
If that does not work, try to format the C: drive while installing the Vista operating system.
You need to select the "format" option from "advanced" within Vista installation.
Click on the link below for more information.
Error message when you try to install Windows Vista on a computer that has uninitialized hard disks: "This computer's hardware may not support booting to this disk"
http://support.microsoft.com/kb/925481
1helpful
Would like to install drivers and software for my LG Potable Super Multi Drice GP08NU6W on another computer bot lost the CD that came with it. Where can I download the software/drivers. I am on Windows XP...
you wont download it. Do the fllowing step.
1.control panel->system->hardware->DEVICE MANAGER 2.uninstall your driver 3.restart you computer 4.on tray icon a balloon come with a MSG of 'found new hardware' 5.click on it 6.select your driver from it .then select suitable option
if you still have problem buy a you op(win xp,vista,7..).using that disk repair you computer.
1helpful
2answers
When i download installation for my quickcam 3500 , befor i start installation wizard it comes up with an error telling me the download is corrupt or not complete . i have tried this several times with no...
A simple way of insuring your download to be safe is to clean your computer first of any virus, spywares and adwares that might disturb your downloading, doing so would ensure your file transfer to be safe.
My sims 2 double deluxe wont load
try to check first the disk clean it with a soft cloth if it dosent work go to the properties and unlock it to 100% hardware work.....it works a 100%....GL
RX500 and vista
Windows Vista printer and scanner drivers are available for your product. The printer software is available by using the Automatic Software Update service built into Windows Vista. The scanner software is available for download through Epson’s website.
PRINTER DRIVER DOWNLOAD
Please follow these steps to set up your Epson product and automatically download the Windows Vista printer driver for it from Microsoft:
1. Connect the USB cable to your computer and then to your Epson product.
2. When the FOUND NEW HARDWARE window appears, select Locate and Install Driver Software (Recommended).
3. Your Epson product drivers will install automatically. You may need to select this option more than once during installation.
4. Close any open windows on your screen.
5. Try printing.
*NOTE:
-Depending on your system the computer may ask for your Windows disk, if so insert your Windows CD into your CD-ROM drive and click OK.
-As the driver is part of Windows Vista, there is no Status Monitor available for your printer. Some printers may have an INK LEVELS options included as part of the resident driver. Otherwise, the printer does have its own indicators. The LCD will display which cartridge is either low or out of ink.
-If the ink levels do not appear, click GET INK LEVELS to refresh the driver. Ensure the printer is directly connected to the computer as the Ink Levels does rely on full bidirectional communication.
SCANNER DRIVER DOWNLOAD AND INSTALLATION
1. Go to the Epson Support website (www.epson.com/support).
2answers
Trying to install my web cam
I have windows XP professional OS and i have connected Veo Stingray web cam after installed driver its do's work,
I want sollutions if anybody can help me.
Please help me out.
Thanx
1helpful
5answers
DOWNLOADING CAM
If you have the installation disk you already have the driver. You have to BACKDOOR Vista. Put the disk in the cd drive. Exit the installation then go to my computer or just computer whatever your says. Then right click on the Veo icon. Click on explorer. Then open the drivers folder. Right click and COPY the folder that says winxp on it. Paste it to the desktop. Then plug the cam into the usb port. Now manually in stall the driver. When it ask to find the driver click on browse. Then find the folder you just copied. Then click next. I have the same cam and it worked for me. Hopefully you can figure out how I did it.
1helpful
Hard disk problem
If your Wundows vista is a full install program you should have deleted and created the partion then formatted the new partition before installing windows vista. Try this again if you hard drive is stuffed you will need a new one Im afraid but windows vista will tell you this before it installs itself. Goodluck!!!!!
2helpful
C3140 PRINTER NOT PRINTING - HELP
How long ago did you purchase the printer? Does it have the "Certified for Windows Vista" logo on the box? If not, it won't work with Vista at all. I checked Microsoft's Hardware Compatibility List and it says the HP Photosmart C3100 series is *certified* with Vista, however it does not say it *works* with Vista. http://winqual.microsoft.com/HCL/ProductDetails.aspx?m=v&g=d&cid=900&sv=&f=86p&pn=HP%20Photosmart%20C3100%20series&oid=31 Per the link, the driver may be part of the Windows Update. Give that a try, as well as HP's website. Otherwise you may need to take it back and exchange it for a Vista-certified printer. Let me know how it works out!
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
