for some reason it is not seeing you cable signal. you will need to make sure you have it set up for cable and not air. check your input options, like tv/av/hdmi/ ect
hope this helps
Press MENU button on the remote control and select Install and Retune by using Left or Right button. Press OK button and the following menu screen will be displayed
Select Automatic Channel Scan (Retune) by using Up or Down button and press OK button. Automatic Channel Scan options will be displayed. You can select options by using Up or Down and OK buttons.
Auto Channel Scan Menu Operation Digital: Searches and stores aerial DVB stations. Analogue: Searches and stores analogue stations. Full: Searches and stores both analogue and aerial DVB stations.
Whenever you select an automatic search type and press OK button, a confi rmation screen will appear on the screen. To start installation process, select Yes, to cancel select No by using Left or Right and OK button.
After auto channel scan type is set and selected and confi rmed, installation process will start and progress bar will move along. Press MENU button to cancel process. In such a case, located channels are not stored. The television will start to search for all available stations. You must allow the television to complete the search.
I stumbled across this feature by accident :-) --------------------------------------------------------------- Press the "OK - Enter" button. Your list of auto-scanned channels will appear. Key in the channel number. Ex. 101-5 Then press the "Left browse arrow". The channel number will now appear grayed. To re-activate the channel just key in the number again and now press the "Right browse arrow". Use the Up or Down browse arrows to page through the scanned list.
I have experienced exactly the same issue on two Westinghouse sets. Try turning the set off when it reaches 83%. When I turn mine off and back on, it has saved the channels -- at least the ones it had found before it got hung up.
