20 Most Recent
Dynex DX-LCD32-09 LCD TV Questions & Answers
I have a dynex 55 inch tv it turns and runs for a
I would recommend doing power cycling your TV. Turn it off, unplug it and leave unplugged for a few minutes, then plug it in and power it on. If this doesn't fix the issue, then I would also ensure settings are back to factory defaults. Press MenuPress Left or Right to select Setup, then press Down to open the Setup menu.Press Up or Down to select Restore Defaults, then press Right or Enter. When a message asks if you want to restore factory settings, select Yes to restore the settings, or select No, to exit without restoring settings.
1/19/2018 10:01:34 PM •
Dynex...
Answered
on Jan 19, 2018
I HAVE A 32 INCHES
do you have ebay you can use theres alot to pick from
10/23/2017 10:36:37 AM •
Dynex...
Answered
on Oct 23, 2017
Dynex PO2-w30-003s no picture sound ok
put a flashlight behind the TV screen or front screen close, just try as close as possible, if you see image that means that the Back-Light inverte is defective or the screen lamps are not working, if deres no imagen the video card is not working (main board)
8/6/2014 3:27:28 AM •
Dynex...
Answered
on Aug 06, 2014
Why my screen says please wait then goes black
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
5/5/2014 7:46:47 PM •
Dynex...
Answered
on May 05, 2014
