Check that the fuse is not blown and that there is no wiring fault. Otherwise check that the lights are not blown as well, and look at the following YT video to illustrate the removal of the light:
4 way flat molded connectors allow basic hookup for three lighting functions; right turn signal / stop light (green), left turn signal / stop light (yellow), taillight / license / side marker (brown) and a ground (white).brownwire will run both right and left side markers
Trailer end; Red=Brake
Brown=Running lights
Yellow=Left
Green=Right
White=Ground
You will need a turn and brake signal box IF, you have different bulbs for brake and turn lamps. If the brake and turn bulbs are one(red)lens than no box will be required. Thanks, Dana
I'm assuming you're just going to splice into the tail light wiring so that's what these wire colors are:
at the tail lamp 3 way connector:
black and yellow = park lamp
dark green and brown = left turn signal
there should be another connector with violet and black wire for reverse lights.
the stop lights are turned on through the turn signal circuits.
hello release tailgate latch and open tailgate remove screws holding tail light ok depress lock tab on side of connector that the wires go into so press then pull next ,ok to change bulb the round things that look like turn dial on a timer in the kicthen just turn counter clock wise thanks and good luck
