As the title says. Where the cord comes in from the outlet it then goes to a fuse, if you follow the white line on the circuit board it goes to a little transformer, right after that is a little black box type connection (I'm not sure if it's a relay or a breaker but it looks like it can come out by pushing in the tabs, and there's a second one down the board a ways). Anyway, as I push the power button this black box clicks like it's turning on. After about 5 seconds (with nothing else coming on) it clicks again then everything is dead. Could this be the reason the TV won't work? Is this something I can replace from a part at Radio Shack?? Any help with this would be great!. :)
Thanks
Jeremy
[email protected]
Bill, I tried replaceing the STK392-110's and still having the 3 flashes and no responce from the TV, although I hear relays clicking. Is there a posibility that it's the R800 Relay or do you sussecpt something else? Thanks in advance.
Jeremy,
Those are your primary and secondary relays and they are probably not your problem!! In RARE cases R800 will fail causing RI802 to fail (your secondary relay) but I emphasize in RARE cases. The reason they click and then click again is that the shutdown circuit commonly requires them due to some short in a circuit up-line from the B+ and usually I would first suspect the convergence amps.
Your set takes two STK392-110 Sanyo original Ic's and if you have these replaced I think that will solve your problem.. They're located at Ic7001 and Ic7002 on the signal board, screw mounted to a large aluminum heat sink. On replacing them also check all 2.2 ohm 1w feed resistors out front of them and replace any that may have changed in value...
Bill
ERROR
CODE # 7
E7-
1) Alternative Elevation Motor
1)Cause:
Elevation Motor not moving Solution:Check
Elevation Motor connection
2)Cause:
Elevation Elevation Motor screw binding Solution:
Clean screw and lubricate
3)Cause:
Elevation Motor Motor out of Range Solution:
Check motor out of elevation
4)Cause:
E-Motor Potentiometer: Solution:
Replace Elevation Motor
2)Alternative:
Display
Doesn't Light Up:
a)Cause:
On/Off switch Solution:
Test unit is turned on b)Cause:
Insufficient Power Source Solution:
Plug
dedicated120V, 20Amp Outlet
c)
Cause:
Line
Cord Damaged Solution:
Replace Line Cord
d)Cause:
Fuse Solution:
Check Fuse on MCB
Have the same exact problem, I'm wondering if what you mentioned will have to soldered in or not? I havn't looked at it yet, but this is def. what is happening with mine.
Same problem here. Is there a definite fix? Does someone have step by step instructions or diagrams for the replacement of the broken components?
I had the same problem and now the TV will not even power on. I had a TV Tech come by the house and he said he had to pull out one of the circuit boards and replace a fuse on the board behind it. Approximately $500.00 for the repair. Is my problem the same as Jeremy's? If not what might it be? In either case I am a Signal Network Tech in the Army and could replace the parts myself, I am just usure of what to order and where to order them from. Any guidance is greatly appreciated. Thanks.
Michael
I have the same problem and tried replacing the Convergence amps, STK yada yada.. NO CHANGE, just a big waste of 3 hours. If anyone else another solution I am all ears, I stll have all the parts diconnected so any help be would be much appreciated!
