Hi there I have recently bought a Panasonic Viera 32'', I have installed the Sky Box and Bush VCR/DVD Recorder Combi correctly but when I turn onto AV2 and switch on the DVD player the screen comes on but is bright green! I have tried all suitable tuning methods and have been through the installtions time and again and checked all cabling but it will not change, it can't be the Bush Combi as it worked perfectly with my previous Samsung set, this is really frustrating, I can't see that it is a fault with the set as the Sky works perfectly and I have tried the connections on both AV1 and AV2 and it makes no deffrences
Look at rear of the Combo and you will observe input and output
RCA connections.Using RCA leads, hookup the Av output of the Panasonic
to the audio/video input of the LCD . Connect the AV output of the Sky box to the AV input of the Panasonic
combo.
Connect the sky to the tv using a scart from the one marked tv on the sky box.Connect a scart from the one marked vcr on the sky box to av2 on the dvd.You then select av2 as your record channel on the dvd.
hello.on that samsung you probably have more than one hdmi conection so conect your dvd/vcr with hdmi cable to tv and sky box with hdmi to if its have hdmi or with scart if not.if you still have problems with conection,make some photos of tv,dvd/vcr and sky box all back panel and send to me ([email protected]) and i send you the best solution i can.
Connect the AV output of the Sky box to the AV input of the Panasonic combo.Look at rear of the Combo and you will observe input and output RCA connections.Using RCA leads, hookup the Av output of the Panasonic to the audio/video input of the Sony tv. Power up Appliances, and you should be OK.
if there is a scart connection on your bush tv then
you can use your panasonic dvd player on it, trust me
just look all over the remote carefully for an AV button, or failing that press channel up or down whilst the DVD is powered up and playing a disc and you will have solved it
