HP DeskJet F380 All-In-One Printer Logo
Posted on Dec 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i scan using a HP desktop F380 - HP DeskJet F380 All-In-One Printer
Starnley Johnwells
Level 3:
  • Master 1,031 Answers
  • Posted on Dec 29, 2009
Starnley Johnwells
Master
Level 3:
Answers
1031
Questions
Helped
607767
Points
3590
Deskjet F380 features a scanner within the upper portion of the device. "Scanning" an item describes the electronic process of converting pictures or text to data, then transferring that data to the computer as an image. Scanning an item into the computer is a simple task with the F380, the only limitation is the size of the item,
follow the steps below
Step 1
Turn the unit on by pressing the "On" button located at the top control panel. The control panel is located on the left side of the unit. The "On" button will illuminate to indicate that the unit is receiving power.
  • Step 2 Load the scanner with the item to be scanned. First, lift the lid of the F380 to the upright position to reveal the scanning surface. Place the item to be scanned face down onto the scanning surface. Position the item so that the edge of the item rests squarely against the front left-hand corner of the scanning surface, then close the unit's lid.
  • Step 3 Press the "Scan" button located at the lower left-hand corner of the F350's control panel to start the scan. If necessary, the scanning process can be stopped by pressing the "Cancel" button located just to the left of the "X" on the control panel.
  • Step 4 Save the scanned image to the computer when the scan is complete by clicking the "Accept" button on the window that appears on the computer's monitor.
  • Add Your Answer
    1helpful
    Please tell me the procedure to scan using my hp deskjet f380 all-in-one series printer
    if it installed corectly, you can scan with program adob photoshop, imort from
    How do i scan from my printer suing macbook pro
    Install the all in one software/drivers, you should now have printer and scanned icons on your desktop.
    You can now SCAN from your SCANNER
    Printer hp deskjet f380
    If you have Vista as your operating system, Windows Vista provides a basic set of scanning drivers, also referred to as Windows Image Acquisition (WIA) drivers, that you can use as an alternative to scan a document when you cannot scan using the HP drivers.You can still scan with one of the following methods:
    (Click here) workaround
    My hp dekjet F380 all-in-one
    Do not place any paper on the scanner and open the lid and press scan button and check if the light glows and moves forward and backward. If the light does not glow its a problem with scanner light.
    Also try to uninstall and reinstall the printer drivers.
    Else please refer the weblink given below
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00704831&cc=us&lc=en&dlc=en&product=1128296
    How do i scan a document so that it can be saved on my pc?
    connect the printer to your pc using usb cable .install the driver of the printer (hp deskjet f380 all-in-one ) . after complet the installation one hp solution center named one icon will come in desktop open that one and goes through the process (scan document ...>select where u want to scan ..>scan )
    2answers
    My hp deskjet f380 will not scan on my vista computer..saw instructions to click on " paint" but where do i find " paint"
    DOWNLOAD SOFTWARE FROM THE WWW.HP.COM SUPPORT AND DOWNLOAD
    write model
    selct vista
    download software
    use this software interface you can scan easily
    I can print and copy, but not scan with HD F380 using Vista. Help
    Ensure any program that came with the scanner is installed on the computer and running (open the program).
    1helpful
    Scanning a photo
    Make sure you have the HP imaging software installed and running first if you dont you can download the Vista version HERE that should do it
    52helpful
    10answers
    HP Deskjet F380 All-in-One Compatible with vista
    I had the same problem. I could print, but not scan.
    However, if you open up Paint and go to file and scan, it will scan your document. For some reason, using the scan button on the printer itself will not work with Vista, but using Paint will. I also heard that using Windows fax and scan will also work.
    good luck
    k24674
    Grand Canyon Tech
    Grand Canyon Tech
