the problem is the website doesnt have support.. wish somebody can give me link its really frustrating i cant find any><the problem is the website doesnt have support.. wish somebody can give me link its really frustrating i cant find any><
You can't post conmments that contain an email address.
On computer driver, if you lost your cd drive disc or broke the cd you can download them by doing the following steps:
1. Go to your manufactor's website. 2. There should be a search bar on the top of there website. 3. click in the search bar and enter your model number of the computer or you can enter hardware model. 4. After you hit you come accross to technical support page click on that. 5. There should be a word pertaining drivers click on that. 6. Finally, click download and download the correct version of driver for your windows.
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats
ticking over in the background on your computer if you see something running that you dont need running select end now then also select users you will see who is (USING) your computer right click on that user select either log off or disconnect
or if you right click on the network in the bottom toolbat select open network sharing you will have many options to disconnect or choose home sharing options this will vary depending on your operating system
should be 192.168.1.1 which is the default ip for most device. if you connect it to a router/switch you will have to remove and connect it to directly to your link source to configure it. After this you remove and connect to your router/switch since you have configured an ip for it to use. If you are using this as your modem then the above ip should work for this abd note that some service providers do not allow wirless as being its modem so check with your service provider if you are using this on the internet.
Again when you configure note that you can assign an ip from 192.198.1.2 going to the device if you are note using that as the modem.
To configure the device connect it to the main souce of link. open a browser and enter 192.168.1.1 (which is the default modem address). when asked for a password enter admin, username is also admin(this is for most device and if it does not work for you refer to the device manual for its default username and password).
Guess you should find your way out in the configuration. For more help refer to the device manual like i said and also find out more information from your isp.
good luck
You are tying to set up the router . It is very easy ! first make sure that your main computer will be able to go online when connected directly to the modem, without the router. Once you are able to go online through the modem, that means the modem is working. you can set up the router manually. Click Here for step by step solutions
