I have a Mitsubishi WD73642 model which I'm having a problem with it turning off. When power is turned on the status light flashes green and appears to be powering up. Then u hear sound. Picture comes on light turns sold green then within a minute the El TV will just turn off no other dianososis lights. TV is not located too close to the Wall. Any ideas why?
I also have a Mitsubishi LT 55164 with blinking green status light...does nothing else...reset does no good, also tried to reload software with no difference. Replaced power and inverter boards button stop the same. No obvious bad components on boards. Help! Anyone ever actually fix one of these?
There are 3 different LEDs on the front of this televison. The TIMER will blink green. The STATUS will blink orange and the LAMP will flash red or orange depending on if there is a failure or if the lamp timer is showing over 5000 hours.
If I answer your question directly and the status is blinking a steady orange light, then you have left the side filter cover or the front lamp cover off or they are loose.
Also holding the menu and device buttons together until the timer light blinks will reveal a code that will help in diagnosing your problem. Goodluck.
error code 37 is either the dmd fan or the lamp fan. you can see the dmd fan with the cover off. you cannot set the lamp fan as it is under the light engine. I guess the easiest thing to do is get a lamp fan 299P282010 and a dmd fan 299P283010 and change them both.
ok here new tips on v26 chaisscust install new oem lamp with led lamp just blink only many time install new balister still shut down no audio no hv at all come with code 34 for test turn out to be that in power supply ther caps that wher blow up 3300 mf at 16v two them c9a38 ad c9a36 both same also note c9a62 1000mf at 16v thru c9a52 ad c9a82 ad c9a61 all 1000mf at 16v install 63v at 1000mf all same with both 3300mf at 25v fix the set now turn on with great pix cust old lamp too dark for pic install new lamp pic better ad reset lamp timer all good cust happy that cust got from mist the power supply board from looking from back of the set on left hand side all way in front u hav pull whole dmb bd to get to it want lets yu guys know[john leyva american video service center ] the right model number is this WD52525 HIT BAD KEY THIS RIGHT MODEL NO WD52525
