Linksys WRLS BRIDGE |WMB54G MUSIC R Logo
Jean-Bernard Minster Posted on Dec 25, 2009
The linksys utility always sends signal to PC speakers, even when wmb54g unit shows connected. The wmb54g and router are up-to-date and run WEP 128 security encoding. The wmb54g flashes faster when connected by switching from PC speakers, but the sound still comes from the speakers, and no signal appears on the component output, co-ax output or headphone output. I have re-installed both the router and the bridge several times after re-setting to factory settings, and tried other security levels.....same result, Could it be the firmware on the audio card?
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Dec 26, 2009
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
416
Points
I can disable the sound card, set the music bridge as the default sound output device and it works just fine (after rebooting). But if I enable the sound card again, even when keeping the music bridge as the default, the sound goes exclusively to the PC speakers, no matter what device the connection is switched to on the Linksys utility. (By the way the music bridge shows correctly to be connected or disconnected....with no effect on the sound output.) The major hassle is that any usable change of output device requires a reboot. Still testing. Not a single answer from the community. Also I never required the promised temporary password.
2answers
tip
Enabling Wireless security on Linksys routers.....
Encrypting the network blocks any unauthorized computer from accessing the network and using its broadband connection. To enable WEP on the router,
1. Open your default browser and enter the following IP address into the address bar: <http://192.168.1.1>
2. When prompted for a username and password type “admin” on password, unless you have previously changed the password of the router, and hit OK. This will bring you to the Setup page of the router.
3. Depending on the firmware of the router. Click on the WEP Key Settings button. Or you can click the Wireless tab and select Wireless Security. Or you can click the Security Tab and select Wireless.
4. From the WEP/Security Settings window, you may enable 64 or 128 bit WEP then enter your Password on the Passphrase field and click on Generate. Make sure to copy the characters on Key 1-4 on a piece of paper before you hit APPLY. You will be needing this once you enable WEP on the wireless PC’s. Also take note that if you enable 64 or 128 bit on the router, this should be the same WEP level that you will enable on the wireless cards.
To put in the network key in your wireless adapter follow the steps below:
WEP Encryption XP's Wireless Zero Configuration ( Advisable for XP PC's )
1. Go to start>Control Panel>Network Connections>Right click on the Wireless connection then click on Properties>Click on the Wireless Networks Tab
2. From the Wireless Network Connection properties window, under the Preferred network click on Add then type your SSID on the SSID field and check the box for Data Encryption then then unchecked “The Key is provided for me Automatically”
3. Type your WEP Keys on both the Network Key and Confirm Network Key field. (This set of characters should be identical to the WEP Keys Settings on the router. For 64-bit WEP you should have 10 characters, for 128-bit you should type in 26 characters.) Then hit OK and then OK again.
4. After hitting OK a pop-up should appear on the lower right hand side saying “Connected”. Try pointing your mouse arrow on the lower double monitor icon.
5. Restart your PC
WEP Encryption using the Linksys WLAN Utility ( 98/Me/2000 )
Make sure that the WLAN utility of the Linksys adapter is already is installed. If not, you may follow follow the procedures below for "Installing the Linksys WLAN Utility"
1. Click on Start then Programs, then click on anything that says something about the Linksys Wireless Adapter. On the menu, select either WLAN Utility or Wireless Configuration Utility
2. On the lower right-hand side of your screen, double click on the Linksys Icon. This will bring up the WLAN Configuration Utility.
3. Click on the Profiles Tab. Make sure that the SSID that is set to default is your routers SSID. Highlight Default then hit Edit.
4. Select Profile Wizard. Continue to click the Next button, until you get to the Security Settings Window.
OR select Expert Mode then Next. Then click on Security Settings
5. Set the same WEP level that you have enabled on the router. ( ex. 64 or 128 )
6. Type your WEP Keys. This set of characters should be identical to the WEP Keys Settings on the router. For 64-bit WEP you should have 10 characters, for 128-bit you should type in 26 characters.
7. Hit OK then Next. On Confirm New Settings click Yes. And then click “Activate New Settings Now”
If this is a Helpful tip Thumbs Up is appreciated. Thank you
How do i set up the wireless bridge without a
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Does not save wireless security settings
2. From the Wireless Network Connection properties window, under the Preferred network click on Add then type your SSID on the SSID field and check the box for Data Encryption then then uncheck “The Key is provided for me Automatically”
5. Restart your PC
1helpful
2answers
How do I put an encryption on my linksys router?
Securing your wireless network is a simple process, which generally does not require a lot of time. This can be done by:
  • Enabling WEP or WPA on the Router
  • Enabling Wireless MAC filter on the Router
  • Disabling SSID Broadcast on the Router
NOTE: The wireless security modes available may vary depending on the model of the router and wireless adapter you are using.
Enabling WEP on the Router
Wired Equivalent Protocol (WEP) is a type of wirelesssecurity which does not change. It provides comparable confidentialityto a traditional wired network. There are two types of WEP you canchoose from:
a. WEP 64-bit: This type of WEP consists of 10-hexadecimal codes. To enable WEP 64-bit, click here.
b. WEP 128-bit:This type of WEP consists of 26-hexadecimal codes hence it is moresecured compared to WEP 64-bit. To enable WEP 128-bit, click here.
Enabling WPA on the Router
Wi-Fi Protected Access (WPA) is a type of wireless securitywhich is dynamic in nature. Meaning, it changes depending on the timerenewal you will specify. Hence, WPA is more secured compared to WEP.
  • Temporal Key Integrity Protocol (WPA-TKIP) – utilizes a stronger encryption method and incorporates Message Integrity Code (MIC) to provide protection against hackers.
  • Advanced Encryption System (WPA-AES) – utilizes a symmetric 128-bit block data encryption
To enable WPA, click here.
Enabling Wireless MAC Filter on the Router
Wireless access can be filtered using the MAC address of thewireless devices transmitting within your network’s radius. You caneither permit or prevent specific wireless computers access to yourwireless network.
To permit wireless computers to connect to your wireless network, click here.
To prevent wireless computers to connect to your wireless network, click here.
Disabling the SSID broadcast is one way of securing your wirelessnetwork. This procedure will prevent other users from detecting yourSSID, or your wireless network name, when they attempt to viewavailable wireless networks in your area. For instructions, click here.
Can you run WEP and WPA simultaniously?
If you did do both simultaneously, and you can on the separate systems, you would experience a severe denigration of your service in terms of speed and the real possibility of a lot of down time.
Yes, you can, but should you is the real question. If the linksys only does WEP and you want the N speed, then switch off the encryption of the lynksys.
3answers
Linksys WMB54G: No Connection Via the Software Utility
It appears the configuraion IP address you are using is wrong it should be 192.168.1.100 or 192.168.1.1
5helpful
3answers
Wireless printing with AT&T U-verse and 3800 HGV-B and Linksys WPSM54G
I may not be able to completely solve the issue for all who posted, and I have not gotten the scanner part of my Brother MFC-5440CN printer/scanner/copier/fax to work through the wireless PS, but I can at least shed some light:
First off - trying to make the Linksys WPS54G work on a wireless network that has a decent level of security is NOT for the faint of heart!
Key issue is security; make sure you know what wireless security protocol your router is using (WEP-64, WEP-128, or WPA). My U-verse installation uses the exact same 2Wire router, but either it defaults to WPA security, or the tech set it up that way without asking me. WPA is preferable anyway, as it is the most secure, and I had my network set up on WPA with my ZOOM X6 when we had AT&T DSL.
The problem is that the Linksys unit is old/obsolete enough that it defaults to WEP or no security, and in fact the setup program and utilities on the CD that came with the refurb. unit I recently bought are way outdated compared to the current downloads available on their support site, and don't even offer WPA as an option.
If your U-verse router is configured for WPA, as is most likely, then you have to get your Linksys unit configured for WPA security before it can be properly "seen" on the network by your computers. This means either downloading the latest setup/driver programs from Linksys's support website and burning a fresh setup CD, or getting to the Web-interface of the unit and setting it there (I could not even get to the web-interface because of my firewall and other security). Only then can you set the unit to use WPA security with the same key/passphrase as your U-verse router and your computer(s).
I'd advise downloading the latest stuff in any case. I ended up downloading the latest firmware, upgrading it on the unit using the Bi-Admin util on the setup CD, setting up the unit using the web-interface (be patient, because sometimes the page loads can be very slow when it is reading or writing settings). I have never been able to access the web-interface from my laptop, which is probably the most secure on our network. I was only able to get things working when I accessed it from an old PC we rarely use, and it is only running Windoze (XP) Firewall for security. The print server had to be Ethernet connected to the router while doing the configuration to make it work.
Securing wireless router
Click here for a link to the instruction manual. All this was retrieved from p.48
First off make sure your wireless connection is working
1. On the Setup tab of the Router’s web-based utility, click the Enable radio button next to WEP. Then click the Edit WEP Settings button.
2. You will see the 2.4GHz, 54g, Wireless-G (WEP) screen (Figure C-1). Next to Default Transmit Key, select which WEP key (1-4) will be used when the
Router sends data. Make sure the receiving device is using the same key.
3. For the WEP Encryption drop-down box, select the level of WEP encryption you wish to use, 64-bit 10 hex digits or 128-bit 26 hex digits. Higher encryption levels offer higher levels of security, but due to the complexity
of the encryption, they may decrease network performance.
4. Instead of manually entering WEP keys, you can enter a Passphrase in the Passphrase field. This Passphrase is used to generate one or more WEP keys. It is case-sensitive and should not be longer than 16 alphanumeric characters. (This Passphrase function is compatible with Linksys wireless
products only. If you want to communicate with non-Linksys wireless products, enter the WEP key manually on the non-Linksys wireless products.)
After you enter the Passphrase, click the Generate button to create WEP keys.
Note: All Wireless-G and 802.11b devices in your network must use the same Passphrase or WEP key.
5. WEP keys enable you to create an encryption scheme for wireless LAN transmissions. If you are not using a Passphrase, then manually enter a set of values in each Key field. (Do not leave a key field blank, and do not enter all zeroes. These are not valid key values.) If you are using 64-bit WEP encryption, then the key must be exactly 10 hexadecimal characters in length. If you are using 128-bit WEP encryption, then the key must be exactly 26 hexadecimal characters in length. Valid hexadecimal characters are “0”-“9” and “A”-“F”.
6. Check all the values, and click theApply button to save your WEP settings and return to the Setup screen. To cancel any changes you’ve entered on this page, click the Cancel button. To get more information about the features, click the Help button.
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
