Kogi L9CH 19" Flat Panel LCD Monitor Logo
Posted on Dec 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The screen moved to right side and i cann't alignement other again at correct posicion
Anonymous
Level 2:
New Friend:
  • Expert 164 Answers
  • Posted on Dec 19, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
164
Questions
0
Helped
90732
Points
461
You can fix this by using the menu button on your monitor, there you can flip through the choices untill you see that you can adjust your h positioning settings
Google screen only (all other screens are correctly positioned) has moved right, can't access right side of screen. can't adjust
Press the windows key on your keyboard, and while holding it down, press the the left arrow key. that will move it to the left.
Why does myd digidoor ii opens fully but does not close ...just moves front then back again
The child safety interlock is not set right. The transmitter and receiver are placed at the bottom of each side of the door. If the transmitter/receiver are not aligned correctly, the door will not close.
Line up the transmitter till the light on the receiver lights up.
How to change orientation of monitor
I'm a little unclear of what you are asking.
1) Screen has turned on monitor?
Press the CTRL key, and ALT key down at the same time.
Now tap on the Left Side Arrow key, until the screen is oriented correctly again.
2) Screen on monitor has shifted left, right, top, or bottom?
Use the controls on the monitor to set it correctly again.
3) Using dual monitors?
Right-click on an empty space on your desktop screen.
Left-click on Properties at the bottom of the list.
Left-click on Settings.
The monitor 1 icon is supposed to be your Primary monitor.
The monitor 2 icon is the Secondary monitor.
Ordinarily the Primary monitor is on the LEFT side, and the Secondary monitor is on the RIGHT side.
Just as shown in the Settings window.
If you wish to move a monitor to the other side, go to the monitor icon you wish to move.
Put your mouse cursor on the monitor icon you wish to move.
Left-click, and hold the left mouse button down.
Now drag the monitor icon you wish to move, to the other side.
Not doing it for you?
Then post in a Comment with more exacting information, as what it is that you wish to do.
Regards,
joecoolvette
Why is my yahoo mail now in the right hand corner of the page?
If I understand your question correctly, your Yahoo Mail shortcut is on the right side of your desktop and has moved from the left side. If this is the case,
1. please right-click anywhere on your desktop, View, and make sure that the "Align icons to grid" box is checked.
2. also, you can right-click again on the desktop and Sort
If this isn't what you're asking, perhaps you're asking why the Yahoo Mail icon is in the lower right task bar? If so,
1. you can right-click on the task bar and depending on which operating system you have, click Properties and Customize.
Thanks for using FixYa
The information printed on My troy micr 2420 laser is not properlly aligned on draft paper. how do correct this? Pls help urgently as the client is waiting.
Hi there!
If not aligned, just turn is off the printer and turn it on. It will self align the cartridge.
If not, turn it off the printer again and unplug the power cord. Use your finger to move the ink catridge from left side and after move it to right side of the printer.
Plug the power cable and turn it on again. Just print again. I will be working by now.
I hope it helps you.
Pioneer SD-641HD5 red convergence - not chip problem!
Replace Both of your STKs if they are STK392-110s do not go back with them use STK392-180s better ICs, The 110s fall apart and do not hold up.
Philips TV Model 32DW6557/05 Screen Problem
hi it sounds like a capacitor in the verticle circuit located on the main board. it is near the verticle ic. the verticle ic also could be bad the cost is around 85 dollars for a tv shop to fix. sometime a cold joint could be found around vert ic. a soldering iron is required with solder.tap the side of tv if picture comes back it is just cold solder joint.
thanks Doctor video
Have black line on right side of screen and cant see all of icon on left side of screen
What type of screen do you have? If it is a CRT (rather than a flat panel) it is probably due to the screen alignment.
Go into the menus on the actual monitor and look for something called Horizontal Alignment (or similar). You should be able to move the whole picture left and right. You may need to play with some of the other settings (e.g. Horizontal Size) to get it just right.
Matt.
2helpful
2answers
Touch screen not responsive
You need to re-align the touch screen using the following routine:
Accessing Alignment Mode:
Then you will see a text message something like
"Press + to align"
STOP
Don't touch the "+" in the text message !!!!!
The one you want will be elsewhere on the screen and all on it's own, with no text around it.
Using the non pointed end of a needle, or the spare spool pin (nothing sharp) gently but as accurately as you can, touch the centre of the +
The + will move to several more locations as it organises the height, width and orientation you give by touching the centre of the + as it appears each time.
When it is finished, turn machine off, then on as normal.
If this does not correct the issue, it may well be something else, so please, if you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
1helpful
Hard drive quantum fireball lct 20
go to quantum website, download manual, check for correct jumper settings
Top Kogi Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Kogi Computer and Internet Expert? Answer questions, earn points and help others
