These are quite tight fitting to begin with. I found it easiest to start with the hood up and put the rain cover on over this part first. Then it is a matter of stretching the cover down over the base of the carrycot. It will loosen slightly with use and become easier to fit.
Hello, if you put the make of the strler in on GOOGLE you should be able to trck down the manufacturer, they in turn may sell you on. The other way is to try E-Bay, you may be able to find one in the many stores that are on there.
I hope this is of some help.
Sounds like your under car plastic panels are missing I would go to your local junk yard and get those covers and put them back under there. I had a hyundai that I took the covers off and when I drove in the rain it would get up in the distributor cap and kill the engine. Also dont drive through flooded areas
The rain cover should come provided with your speedi dreami carrycot. These are quite tight fitting to begin with. I found it easiest to start with the hood up and put the rain cover on over this part first. Then it is a matter of stretching the cover down over the base of the carrycot. It will loosen slightly with use and become easier to fit.
Wow, thats a monster tent. I'll get you most of the way there, but I may miss a thing or two
Lay it down, stretch it out and peg it. That will save you a ton of time.
Next, find the four longest poles. These are the supports. Two on each side of the door, crossing diagonally to the rear. Put one end of the poles in the holes and bend until you can get the other end in. These poles should slide through sleeves in the tent. Once these are up, the rest are "extras." The tent has hooks to hold the poles to the tent.
You have two poles of equal lengths for the side windows. Again, route them thru a sleeve, bending them into the holes on either side of the windows. I can't tell, but it looks like you have a pole system for the front door too. Somehow these poles go next to the main support poles and meet up under the rain cover.
Next, lay the rain cover on top of the tent. It should connect by bungies to the bottom of the pole support holes. There might be a pole or two under the rain cover, but above the tent for support. If so. look for a small pouch that a pole could slide into on the bottom side of the rain cover. You'll run the pole from the pouch to another pouch (all under the rain cover).
Don't worry about strings or extra poles. These are for high wind. Pegging the tent down is good enough.
Since the stroller is discontinued you may consider going to a boat cover shop and having a rain cover made. They will put in the window and everything in whatever color you choose.
