SOURCE: My Kodak ESP5 keeps saying
My esp 5 gave me this same message. I'm not an expert but here is what worked for me.
I turned off and disconnected both cables (usb and power) then reconnected and turned on.
At this point it still read paper jam, so I took ink cartridges out and paper out.
I then reinstalled ink cartridges and PULLED OUT THE PAPER TRAY to it's FULL capacity, added about 5 sheets of paper, and on the main menu I chose the allignment function and printed a test page and suddenly....no jam!
Hope this works for someone. For some reason pulling the tray all the way out cleared the "jam" message for me. Now if I could just get the new ink cart to work I'd be all set! Good Luck!
SOURCE: My Kodak ESP5 AiO printer has its print head stuck at its right.
Dear Sir/Ma'am,
• To resolve this issue remove the cartridges and then the printhead (Upon removing the cartridges look into the slot where the black cartridge fitted into. On the vertical wall at the back you will see two small contact points. Place your finger above those points on the black plastic and run your finger towards the top of the printhead. You will feel a little button and by pressing it , it will release the printhead.)
• Remove power
• Please now check for any objects or paper that might be obstructing the movement of the printer carriage - if any are found please remove them
• Wait 5-7 minutes
• Reinsert power
• Reinsert printhead (When inserting the Printhead please ensure that you hear it click into place)
• Then re-insert cartridges, black first then colour.Please also ensure that you hear them clip into place
Regards,
CViveiros
SOURCE: how to fix paper jam in kokdak esp5 printer
www.kodak.com/go/itg
Select all-in-one printer
Select paper jam and follow the steps
