Vacuums Logo
Posted on Dec 04, 2009
LUX RENAISSANCE WONT TURN ON. HOSE CONTROL BAG LIGHT IS ON
ELECTROLUX RENAISSANCE WON'T TURN ON. HOSE CONTROL LIGHT FOR CHECK BAG IS LIT BUT NEW BAG IS IN MACHINE AND DOOR SWITCH IS ENGAGED. COULD IT BE THE HOSE OR A PC BOARD?
Anonymous
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Jan 04, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
10
Questions
0
Helped
4212
Points
32
Could be the board in the handle but I found that a lot of the times the contacts where the handle meets the hose just need to be cleaned. It could also be a clogged hose but I'd say it's one of the other two.
Aerus Lux 7000: the full bag light keeps coming on but the bag is not full.
Electrolux uses a pressure differential control valve. This valve measures air before and after the bag. There is a orfice or small hole where the hose connects to the vacuum cleaner, and a orice at the back of the bag canister. As the bag fills up the suction pressure reduces at the hose connection and increases at back of the bag canister. When this happens the control valve has a diaphram that closes, which shuts the vacuum off and gives you a full bag light. There is a thin plastic flange that prevents an o ring on the control valve stem from coming off. The flange breaks, the o rings comes off the stem and the vacuum will shut down indicatiing bag full. The after market price is about 22.00. The valve is easy to replace if you are familiar on electrolux vacuums. When I replace these valves, I use epoxy two part plastic putty on the flange of the valve. It takes 2 days to cure, but the flange will not break.
6helpful
2answers
Lux 5000 put in new bag but when i turn on the
It sounds like the valve assembly (full bag control) is faulty. Threr are two O rings inside of it and the plactic holding the bottom one has broken. You'll have to take it to the shop.
4helpful
2answers
Lux legacy
Actually the problem is inside of the canister itself. You need to change a part called the control valve. Occaisonally when fine particles get inside of the valve it damages the inside of the valve, sending a false reading to the main motor, causing it to shut off. This is a relatively quick and easy repair and should be recieved on a same day basis.
Electrolux Canister - Renaissance model
Probably a clog, because the change bag light is nothing but an airflow sensor.
Check your hoses to ensure that there are no blockages, and also check inside the powerhead behind the brushroll.
-R
1helpful
Electrolux Renaissance canister
there are a couple situations to this issue. one is the bag that was replaced is a incorrect one and it is not meeting the switch for the bag pop circuit. some over the counter bags cause this issue. another problem could be the switch itself. or the bag door not being tight enoug to make contact with the bag.
1helpful
4answers
Full bag system works properly, but doesn't reset easily
Either there is something wrong with your switch. Which it doesnt sound like it. Take it to your dealer or call another one it sounds like the control valve needs to be replaced. I am a dealer 1-866-966-9350.
1helpful
4answers
RENAISSANCE HOSE/VAC
THE RENAISSANCE IS KNOWN FOR HAVING PROBLEMS WITH THE CIRCUIT BOARD IN THE HANDLE.YOU'LL NOTICE THAT MODELS THAT CAME AFTER THAT HAD SLIDING SWITCHES. UNFORTUNATELY THE NEW HOSE DESIGN WON'T WORK ON YOUR MACHINE BECAUSE THE CIRCUIT BOARD INSIDE THE MACHINE WAS CHANGED TOO.AERUS MAY OR MAY NOT STILL MAKE THE PARTS YOU NEED. OTHER WISE LOOK ON E-BAY FOR A NEW HOSE.
ELECTROLUX FOOLISHLY REPLACED IT'S FLAGSHIP STEEL MACHINE WITH THIS DESIGN...A FEW YEARS LATER ALL THEY HAD WORTH SELLING WAS THEIR NAME, HENCE THE NEW NAME AERUS.
3answers
Aerus lux 5500
Hi.
Check & replace any filters that are fitted to machine.
Replace bag with new,
Clear hose of any foriegn items & check floor tool for blockages.
http://dysonmanuals.llc.nu/
Chris..
2answers
Electrolux renaissance power hose
If the wires power a motor then it shouldn't actually matter as the motor is AC which has no polarity.
Top Electrolux Vacuums Experts
eVacuumStore.com
Mike Cairns
Mike Cairns
Kolbrun...
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
