Proform Crosswalk 500 Treadmill Logo
Posted on Nov 30, 2009
Proform Crosswalk Advanced 525X the belt slips and it squeaks when slipping.....I have tried adjusting the end of the belt but that doesnt seem to help
  • Anonymous Mar 16, 2014
    belt slips while running
Jon Schniers
Level 1:
New Friend:
  • Contributor 13 Answers
  • Posted on Dec 01, 2009
 Jon Schniers
Contributor
Level 1:
New Friend:
Answers
13
Questions
0
Helped
8078
Points
25
One possibility is the pulley in the front roller.The shaft that goes into the roller slips making the belt seem as if its slipping. To check it it requires tmarking both surfaces with paint and then see if the mark seperates.
2answers
How do I get the belt unstuck from the right side?
You will need to loosen up the right side one revolution, then run the belt at .5 revolution. Watch the belt then retighten the right side slowly until the belt stays in the center. Once its running in the center for at least 1 min without moving over more to right you can stop tightening.
Exercise equipment service Treadmills Ellipticals and Bikes Parts Assembly...
1helpful
How do you keep belt from slipping
see the video attached and proceed according. God bless you
I lost my safety key for crosswalk advanced 525x. How can I turn it on without the key?
1) I do not recommend to do this. because you must bypass the electronic circuit and you can damage many ICS. if you do not have knowledge in electronic digital. Remember the treadmill fitness is very High Tech machine delicated.
2) will be better go to www. proform.com go to customer service and then parts & manual and order the parts, the best solution.
sincerely.
Belt is slipping and squeaking when walked upon what type of lubricant should be used
Sounds like the motor belt is slipping. Make sure the belt from the motor to front roller pulley is tight.Once you have that adjusted lube and adjust the walk belt. The squeaking is usually from the motor belt. Many treadmills(Proform, Nordictrack for example) use Silicone lube (lube n walk, or silicone With teflon from Lowes works good) Call the manufacturer to make sure it uses a silicone lube.
1helpful
I have a pro form cross walk advanced 525x when i jog on the treadmill the track will stop rotating mid stride
the treadmill should have tension adjusting screws. they'd be on the back of the treadmill where the belt wraps around the rear roller, they're inset and you'll need an allen wrench to adjust them. the screws adjust this rear roller. you'll want to tighten them to increase the tension. they also straighten the belt. if your belt is too fat to the right, you'll want to turn the adjustment screw on the right clockwise to tighten and this will bring the belt over to the left. and vica versa for the belt being too far to the left.
1helpful
My 525x slips. Which part typicaly causes this?
This usually caused by a slipping drive motor belt. remove the hood cover, one screw in rear and 2 on the bottom. There will be an adjustable bracket on the drive motor. Good luck, Tim
1helpful
Proform Crosswalk Dual Motion Cross Trainer Treadmill. motor works great. Rubber on right side under the moving belt has come off so belt slips when in use
I think you are talking about the front roller. It has a rubber sleeve that helps to grip the walking belt. Sometimes you can tighten this enough to keep it from slipping but you run the risk of overtightening and damaging both rollers. We recomend replacing that roller.
2helpful
I have a proform treadmill that slips as soon as i step on track i looked at the belt it looks good how do i tighten up the track
There should be adjustment screws on the back left and right sides. The screws will be horizontal with the tread, and probably need an allen wrench to tighten. If the tread runs straight, tighten each side 1/4 turn at a time to keep them even. Check the tread after each adjustment, and stop as soon as the tread quits slipping.
Top Proform Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
john h
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
