If you have not replaced the headlamp with HID, the next thing, are the high beams on ?
If you turn the high beams on, the indicator lamp on the main headlamp switch should go out.
Next thing would be to check the fog lamp relay in the fuse panel ( passenger side kick panel by the fuel inertia switch ).
The fog lamp relay is a half size ISO relay, you should be able to swap with the trailer tow parking lamp relay ( R201 ), to test with.
The fuse you checked is the F17, the fog lamp fuse for Relay R202, correct ?
Just saw a clarification comment added to another posting, figured it was for this problem
http://www.fixya.com/cars/t3478314-12vdc...
The comment was :
lamps dont work i already check fuse and relay
How did you check the relay ? Did you pull it and bench test the normally open contacts with a meter, while applying power to the coil ?
One sure try is to jumper the normally open contacts in the relay socket, and the lights should work. Jumper the contacts as shown below. Make sure of the pin orientation prior to installing the jumpers.
If the fog lamps do not come on with installed, either the fuse is no good, or the bulbs are out.
To check, remove a bulb ( don't touch the glass with your bare hands, the oil will cause a hot spot, and the bulb will blow out ) and check with a meter between the 2 sockets in the bulb connector.
Sorry did not see this on 26-NOV, it was a clarification on another solution, wouldn't see email updates for that.
SOURCE: Front Fog Lamps
My guess is you have a corroded wire (that has shorted out the connection); known problem for this vehicle.
