The Phone must be on.
The SIM card must be a valid one.
The station you listen to and the network operator you use, must support the service.
The headset or enhancement needs to be attached to your phone. for the FM radio to function properly, it's an aerial as well as a headset.
Therefor if you are in a poor reception area for making/receiving calls it will also affect the radio signal.
You have poor reception or you are trying to obtain a channel that is not available to you in your area. You don't say whether you have cable, satallite or antenna but with digital stations now available everywhere your reception should be perfect or nothing.
The cascadia has an integrated AM-FM-WX, XM?, and CB antenna system, that is also prone to poor grounding. The best solution is to install aftermarket antenna systems for all of the equipment... I am driving a 2013 Cascadia with quite poor FM, and non existant AM, and WX reception. The XM works. I am afraid to hook up my CB to this, as it is pushing too much power, and is a sideband unit. I would like to hang the engineer by his/her toenails from the nearest tree for comming up with this garbage...
Hello Blwas5 hi, If some channels have sound and others none, its either the TV has poor reception or, its the channel's weak signal. check them both or see if your neighbors TV acts like yours. If thy neighbor reception is good, then thy TV has poor reception, you can't do anything to fix that. get another TV with good reception qualities.
Your power antenna wire maybe hooked up to ignition. So when you turn off the car no more voltage is going to your antenna wire so your power antenna goes down causing a poor reception. You must hook up the blue wire on the radio harness to the power antenna wire.
The electrical cord acts as an antennae for this radio. Uncoiling the cord will give the best reception for FM. Rotating the radio (and built in ferrite bar antennae) will give the best reception for AM listening.
