The cigarette lighter fuse for a Chevrolet City Express LT is located in the Engine Compartment Fuse Box. The location of the fuse box varies depending on the year of the vehicle. For instance, in 2003-2007 models, the cigar lighter (power outlet) fuses are numbered 29 (Auxiliary Power Outlets) and 30 (Cigarette Lighter). In 2008-2009 models, they are numbered 33 (Auxiliary Power Outlet) and 38 (Cigarette Lighter). In 2010-2022 models, they are numbered 25 (Auxiliary Power Outlet) and 73 (Cigarette Lighter).
There are at least two reasons why this could be happening. Firstly (and this has happened to me) there could be a foreign body dropped inside the lighter socket, preventing electrical contact. Have a look and remove. Secondly the fuse to the cigarette lighter may be blown. Beware! Fuses do not blow without a reason. If blown, it could be that a conducting foreign body may have been dropped into the socket. Remove the fuse cover and locate the appropriate fuse. DO NOT REPLACE WITH A HIGHER AMPERAGE FUSE. Should be no more than 20 amps. If the fuse blows again, try the lighter on another vehicle. ( A good friend??) If that blows the fuse too then the lighter is faulty with a low resistance. If not then the lighter circuit on the vehicle needs to be checked by an auto electrician. Good luck!
Cheers, Don.
Hi! The cigarette fuse is somehow interconnected with the radio fuse. If no luck, then i believe that the cigarette lighter needs to be replaced. Hope this helps and have a good one!
On some vehicles the cigarette lighter fuse is attached to the cigarette lighter assembly itself. Check if you can gently prise the cigarette lighter assembly out of its location in the dashboard, or remove any panel that may allow access to the rear of the cigarette lighter and look for the fuse (it may be an in-line one in the power lead to the cigarette lighter or it may be physically attached to the cigarette lighter itself). Failing that, the fusebox is normally under the dashboard on the driver side, but some fuseboxes can be found under the dashboard on the passenger side. There should be a diagram under the fusebox cover that shows what circuits each fuse protects. If a fuse has blown ensure that another of the same type and value is used to replace it.
It acts as a circuit breaker. It will be in you TIPM, (totally integrated power module). It's just a glorified fuse/relay box under your hood. It won't look like a fuse, but It will have a clear top so you can visibly see a burn. PTC stands for positive temperature coeffiecient, wich means, as temperature rises, so does resistance until the circuit opens. If may have occured due to an excessive current draw from your cigarette lighter if you have plugged anything into it.
make and model and year of the vehicle please
