Question about Logitech Traveller (980399-0403) Wireless Headset
Hi, I've been trying to get my Logitech F-0399A headset to work. I've installed CallCentral and removed it a couple times but it still doesn't seem to be responding. Whenever I get to the 'play a sound' part on the audio tuning wizard, it stops working. There's an established connection between the dongle and the earpiece for sure though. I've tried removing and installing the program as well as restarting my computer, but nothing seems to work. Thanks!
  • 5 Answers
SOURCE: Logitech USB headset no sound
Have you tried changing the Audio Device that windows is using?
Under the Sound and Audio Devices in the ontrol Panel. Under the Audio tab, try the Default Device under Sound playback. Change this to the headphones.
Posted on Nov 10, 2007
SOURCE: MOdel: F-0399A
Download the manual which is available on this site
Posted on Sep 07, 2008
SOURCE: not charging
We need a charger for this headsets since I am looking for a charger for mine
can you post chargers on the accessories model F-0399A.
thanks
George
Posted on Oct 07, 2008
  • 8 Answers
SOURCE: mic not working when headphone plugged in
Try changing the Windows Default Audio devices
  1. Go to control Panel
  2. Sounds and audio devices
  3. The Audio tab
  4. Then change the Sound Recording Device to Logitech Headphone INPUT
Hopefully this will work
Posted on Apr 07, 2009
  • 5 Answers
SOURCE: Logitech ClearChat USB Headset Model: A-00006
You can buy replacement dongles from Logitech. Don't listen to lawrenceguo
Posted on Apr 02, 2010
When I plug in my Logitech HD720p webcam, the shortcut for it doesn't show up. How can I get it to work?
Hi! you need to install the driver of ur cam.. if your done then try to use it,,, Enjoy!
May 29, 2011 | Radio Communications
I lost the charger for my Mobile Traveller BT Headset, model F-0399A: where can I buy one?
A good cheap source would be ebay.Have a look there and ask the seller any questions if you are unsure and make sure he/she is a reputable one with good feedbacks.Hope this helps.
Jun 04, 2010 | Logitech Traveller (980399-0403) Wireless...
Logitech Headset USB Ports Not Working
Hi my name is Owen,
to fix the headphones uininstall the drivers click start control panel add remove programs and select the drivers for audio logitech audio or creative audio driver and click remove.
http://www.logitech.com/index.cfm/support_downloads/&cl=us,en?WT.ac=pt|3741
Get these drivers, or
Click start, right click computer click properties/ click the hardware tab/ click device manager/ click sound video and game controllers and uninstall the hardware. Then click sound game and video controllers and click scan for hardware changes and install the headset. Contact me with more for quick response.
Jun 03, 2009 | Logitech 980374-0403 Consumer Headset
Logitech problem
Resell It on EBAY
Sell it to me,
Third, to pair to your phone
1) Make sure the earset is charged fully overnite.
2) Turn on your bluetooth function in Phone.
3) Turn on your earset and keep pressed for about 10 or longer seconds until it becomes solid blue and not any blinking versions. This is the pairing mode.
4) Go to the blue tooth menu in phone and try to discover this ear piece.
5) Enter 0000 as passscode and the phone should get paired up.
6) If it says successfully paired , then go ahead to configure how to turn on blue tooth and automatically configure // trust // and connect to the Logitech bluetooth earset.
7) Now enjoy this ..
Beware ; When the ear peice in your pocket or hangbag, if the buttons get pressed in a way it dials out the last number called , then un-intentionally all you conversation you thought might be private or sensitive in nature will be heard by the the person answering your phone , or worse even it goes to their voice mail,, all your scoop is recorded by the modern phone voice mails...
So Be care full and save some embrassment or OOPS , got me with pants down moment...
Mar 17, 2009 | Logitech Traveller (980399-0403) Wireless...
The ear loop attached to my logitech F-0399A bluetooth headset has broken into 2 pieces. Logitech says since I didnt save my receipt, they were at a loss to do anything. Earphone works, I just need...
Ok, You can purchase an replacement part for the next generation logitech travelller Blue tooth. They fit fine .
If you cant find a replacement for the logitech travelller BT set, ask support to send you one and say you will pay up.
If you do buy , get a couple more
Else buy some gorilla glue and follow instructions to make a solid bond,
Bond one piece, Set aside for 12 hours,
Bond another piece and set aside for another 12 hours or over nite... The two pieces should now be solid bonded
Oct 12, 2008 | Logitech 250 Headset
Not charging
thanks
George
Jun 11, 2008 | Logitech Mobile Freedom Wireless Headset
MOdel: F-0399A
Dec 21, 2007 | Logitech Traveller (980399-0403) Wireless...
Premium usb headset
Hi, A couple of things you can check first pls: 1. the logitech headset has its own mute control somewhere along the line/volume control. pls check/try it on both settings; 2. since it is USB connected, it is now a secondary audio device in your hardware aside from the onboard audio device in your computer. That gives you now 2 speaker output and 2 mic inputs. It is possible that voice recognition uses the logitech therefore it works but voice chat uses the onboard audio and since no mic is connected at the rear of your computer (I am presuming), you may have to set the voice chat to use the logitech mike also. I hope this gives you some idea and works for you. Pls post agin how things are or if you still need further assistance. Good luck and kind regards.
Aug 03, 2007 | Logitech 980374-0403 Consumer Headset
Logitech Traveller (980399-0403) Wireless Headset Logo
Top Logitech Radio Communications Experts
Bharat Das
Bharat Das
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
