Question about Logitech Premium Headset
Mic not working when headphone plugged in
Hello, i recently bought Logitech Premium Stereo Headset (with in line headphone volume control and mute button for mic) from ebay. Was working great, untill last night when i tried talking and couldnt be heard by the other person although i could hear them. after much playing around, turns out that the mic only works when my headphone jack isnt plugged in. i even tried pluggin the headphone jack into a non-active aux input on my pc, and as soon as its connected, the mic stops working. it seems that as soon as the headphone jack is connected to anything, the mic stops working.
any suggestions as to what it might be.
thanks
    Problem Solver:
  • 8 Answers
Try changing the Windows Default Audio devices
  1. Go to control Panel
  2. Sounds and audio devices
  3. The Audio tab
  4. Then change the Sound Recording Device to Logitech Headphone INPUT
Hopefully this will work
Posted on Apr 07, 2009
  • Dragazarth Apr 07, 2009
    Oh and make sure you have installed the driver if it came with one, otherwise look on the logitech website
6ya staff
SOURCE:
I have 2 plugs on my Logitech ClearChat Stereo Headset Headset I have a table top computer where do I pug them
The headphone plug goes into the green jack on the computer. The mic plug goes into the red jack on the computer. The headphone plug with have three segments on the jack, the mic plug will have two, and they'll both be marked. If you're computer doesn't have color jacks, the mic will go into the one with a picture of a mic, the headphones will go into the one with a picture of a headphone or speaker.
Jul 07, 2011 | Logitech ClearChat Stereo Headset Headset
I got new Logitech Clearchat stereo headphones. I plugged the two pins into the pc - pink and green. When I do a skype test I hear the message from my computer speakers (settings says Realtek HD..with no...
realtech hd is your sound device. go into windows control panel and access the sound settings then navigate to voice settings click the volume button,your mic might be muted. also if you want the headphones to work plug them into the plug that your speakers are using (side-note: mics and head phones never need something installed to work as long as your sound device works and your definitely does work,only when the mic is a special interface like USB do you need to install software and/or drivers)
Apr 01, 2011 | Logitech ClearChat Stereo Headset Headset
Microphone doesn't work on Logitech ClearChat Premium PC headset. I've checked jacks, mute switch. Ran Paretologic to install proper drivers. Is there an on and off switch for the microphone (not the...
If the mic mute switch is not on and there is no red light in the mic arm then its likely you have a check in the 'mute mic' box in your sound manager. Open Volume control, choose options->properties-> recording. Check for checks in the boxes and remove them. Also make sure the slider for the mic is about half way up.
Mar 19, 2010 | Logitech (980240-0403) Microphone
Computer Does Not Detect Headset Microphone
Sound and Recording jacks stop working on the DV6000 series due to the ribbon cable running under the power button. when the power button is pushed it bends the flex cable and over time it breaks the connection rendering the front jacks useless you can buy a new upper button panel for about 20 dollars on ebay
Aug 02, 2009 | HP Pavilion dv6000z Notebook
Logitech premium usb headset 350 help me pretty please
If when you talk into your mic you hear yourself from speakers...open your volume control(windows) and check the box to mute mic. Not for sure this is a fix to your problem but from what you wrote is similar to problem seen with voice chat software.
Feb 16, 2009 | Video Game Consoles & Games
Headset volume adjustment
if connected to a pc right click on the speaker icon on the right side of the main toolbar in windows then click on playback devices and adjust the volume there.
Jan 21, 2009 | Logitech Premium Stereo Consumer Headset
Just bought my headset TODAY
TURN OFF ONBOARD SOUND IN THE BIOS.REBOOTAND CHECK VOLUME CONTREOL SETTINGS FOR A MUTED MIC.RICHARDM69
Dec 06, 2008 | Logitech (980361-0403) Headphones
Mic doesn work
same thing happened to me, it wouldn't even work when i went to control panel -> audio devices -> mic test   i think i'm just going to return it for a different model.
headphones worked well though
Sep 23, 2007 | Logitech Premium Headset
Premium usb headset
Hi, A couple of things you can check first pls: 1. the logitech headset has its own mute control somewhere along the line/volume control. pls check/try it on both settings; 2. since it is USB connected, it is now a secondary audio device in your hardware aside from the onboard audio device in your computer. That gives you now 2 speaker output and 2 mic inputs. It is possible that voice recognition uses the logitech therefore it works but voice chat uses the onboard audio and since no mic is connected at the rear of your computer (I am presuming), you may have to set the voice chat to use the logitech mike also. I hope this gives you some idea and works for you. Pls post agin how things are or if you still need further assistance. Good luck and kind regards.
Aug 03, 2007 | Logitech 980374-0403 Consumer Headset
Head set problem with vista
you will need to go into the sound manager in control panel and make sure that the external mic is enabled as the default use and ensure in the sound settings that the mic is not muted, this is normally done by right clicking the speaker icon in the taskbar and selecting options and see if the mic is muted or not in the properties
May 26, 2007 | Logitech Premium Stereo Consumer Headset
Logitech Premium Headset Logo
3,245 people viewed this question
Top Logitech Radio Communications Experts
Ekse
Marvin
Marvin
Thomas F. Schneider
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
