Samsung DVD Camcorder Logo
Posted on Nov 14, 2009
I have a Samsung 34x digital camcorder RW-R model. After recording to a disk, when I go to record again it erases anything that was originally on the disk. I've seen other complaints about this. Is there any way to stop this from happening?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 07, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1161
Points
Pokazuje ze dvd jest pelna lub ze cd nie ma
1helpful
Im trying to view previously recorded videos on my camcorder but its asking me to reformat it
Yes, this happened to my miniDVD-R and -RW disks as well. No, don't reformat the disk !
I've been able to recover all (if not most) of the contents - video clips from those (bad/corrupted) miniDVD-RW ... and miniDVD-R disks ... (that I had recorded using the Samsung camcorder). I use the software tool - IsoBuster Pro . Inserted the mini-DVD into the DVD drive on my PC/laptop, and started the software . The process (to recover) may be very long .. i.e. it may take several to many hours for one miniDVD disk ... but it eventually enable me to retrieve the (lost) video clips.
5answers
Howe to erase adisc that I have just recorded?
format disk under windows..if that's what you have as an option..this will not provide the same density, however, as a manufactured disk
How do you delete songs on a burned disk on windows 7
you cant delete anything that has been burnt to a disk unless its a its a dvd -rw
Short for DVD-ReWritable, a re-recordable DVD format similar to CD-RW or DVD+RW. The data on a DVD-RW disc can be erased and recorded over numerous times without damaging the medium. DVD-R, DVD-RW and DVD-RAM are supported by Panasonic, Toshiba, Apple Computer, Hitachi, NEC, Pioneer, Samsung and Sharp. These formats are also supported by the DVD Forum.
3helpful
2answers
When i insert a blank disk i get cannot format disk message
sorry that you getting this message......... but the ch-dvd 300 is not a recording machine........it only plays recorded DVDs
Erasing the disc
it would actually depend on the type of disc your using for you to be able to erase the contents of the disc and reuse that same disc for new recordings. it's called "formatting the disc". it deletes all recordings and returns the recording medium to its original empty state. this operation is possible if you are using dvd-rw or dvd+rw (re-writeable) discs only. please refer to pp.12-13 of your camcorder's instruction manual for more information about disc format features. hope this helps. thanks:)
3helpful
On my Marantz CDR-630, how do you erase unwanted tracks after recording and before finalizing. I see there's a "erase" button but it won't do anything. Fred, [email protected] Thanks!!
Which recordable disks are you asking about? "Erase" will only work on CD-RW and does nothing on CD-R.
Once you've recorded onto CD-R all you can do is add additional material to it until the disk is finalised to allow it to be played on virtually all CD players. The same goes with CD-RW, but with those you have the option to erase the entire disk and start again from scratch. You can also delete individual tracks from a CD-RW but the space does not become available for additional recordings until the disk is totally erased.
Perhaps you'll find the .pdf manual to be of use:-
http://www.vegalab.ru/forum/attachment.php?attachmentid=65482&d=1256129031
I hope that this has answered your question, all I ask in return is that you return the favour by rating my answer.
1helpful
I have a samsung 34X zoom camcorder RW-R duel layer recorder. After I am through filming...what do I do to finalize it?? When I take it out of the recorder and put it into my dvd player, it is blank. So...
you have to upload the film onto your computer and change the settings so that it can be put on to a cd/dvd for your dvd player to work it. hope this helps.
I recorded a video in my sony handycam dvd and its haf recorded.now it is showing a msg that do u want to make it recordable.i want to keep the previously recorded video and continue recording.what do i do...
The possibility of this varies from handycam to handycam but it is most likely related to the type of disk you are using.some disks can only record one session. it is important to read the instructions that came with the disk.generally disks marked 'DVD-R' can only record one session whereas disks marked DVD-RW can record several sessions and can even be erased and recorded on again as new.
pse reply if this helps you
Luwangula
Will not read disk recorded on Samsung DVD digital Camcorder
The disk needs finalizing.
However this then will make the disk unusable for anything else
Switch to CR R or DVD R as appropriate
3answers
DVD Camcorder appears to have erased disc mid record!
I know it won't play in a dvd player till it is finalized. Leave it in camera mode, hit menu, and scroll down till you see the option to finalize. If you finalize it, it should play in a dvd player. I am having a problem with my camera(same model) where it won't finalize the disc. Any help out there?
Top Samsung Video Cameras Experts
302lab
Level 1 Expert
NOEL
NOEL
 Grubhead
Grubhead
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
