20 Most Recent Samsung SCL901 Hi8mm Camcorder Questions & Answers
Possible that there is loss of sync from the signal and so it is unstable on both the viewfinder and the LCD display. This can be a fault on the main board- processing section. It can also be related to weak passive components or development of moisture. Leave the camera ON for few hours , place it on a warm surface - near to a table lamp and see if the fault changes. If so you need to keep using the camera often to keep the circuits active.
Samsung SCL901... | Answered on Oct 25, 2011
You need this cable or one that is labelled as USB to Mini USB.
http://www.amazon.co.uk/AmazonBasics--Male-Mini-B-Cable-Meters/dp/B001TH7GUK/ref=sr_1_1?ie=UTF8&qid=1307984144&sr=8-1
http://www.play.com/Electronics/Electronics/4-/5889160/USB-2-0-5-Pin-Mini-B-Cable-1-8-Metres/Product.html?searchtype=allproducts&searchsource=0&searchstring=mini+usb&urlrefer=search
Samsung SCL901... | Answered on Jun 13, 2011
You can download and print the instruction manuals in PDF format by clicking these links:
SCL906
SCW61
Please note: Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
Hope this solves your problem. Thanks for using FixYa.
Samsung SCL901... | Answered on Sep 19, 2010
This is more of a problem with charger than Battery, check if power pack gets warm after 30 min or so, if cold it is not going.
Samsung SCL901... | Answered on Jun 23, 2010
Hello, The errors you are getting are "reel" errors. One or both of the tape reels are not turning during tape movement and the camera is shutting down to protect itself and your tape. In this model this problem is usually caused by the take up reel shaft being bent due to improper insertion of the cassette although this may not be the case. Please inspect both the takeup and supply tape reels and insure they are in correct alignment, if not, a gentle push to one side or the other will place them back in operating position. Good luck to you. Joe Weibel CustomElectronics.Org
Samsung SCL901... | Answered on Dec 28, 2009
you might want to press and hold the reset button in ?
Samsung SCL901... | Answered on Jul 31, 2009
SOUNDS LIKE YOU BLEW A INTERNAL FUSE TO THE MAIN BOARD. IT IS VERY COSTLY AND IS HARD TO DO.. SORRY YOU MUST GET A ANOTHER ONE. YOU MIGHT WANT TO CHECK FOR A CANON ?
I don't know if this will help at all but I have had to push the adapter into the camera further than my initial try before it would start charging. Check to see if you can push it in any further.
Samsung SCL901... | Answered on Dec 13, 2008
Make sure that all of the pins in the S Video cable are not bent. I've seen that cause the video not to work.
Does it still do the same thing if you were to use a standard video connection to your video player?
Samsung SCL901... | Answered on Jul 17, 2008
Sounds like the memory stick is corrupted and needs to be replaced.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Samsung SC Video... | Answered on Feb 13, 2018
i think it has an inbuilt memory but the files from the camcorder is transferable through data cable.
Samsung SC Video... | Answered on Apr 04, 2012
Contact manufactures website and search for answers. Otherwise call into a dealer and ask has how you can reset password.
Samsung Video... | Answered 10 hours ago
Then buy one. Accredited dealer or Ebay probably best bet.
Samsung Video... | Answered on Apr 14, 2019
Samsung SCL901 Hi8mm Camcorder Logo
25 questions posted
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
View Most Popular
SC Samsung
  • SC Samsung
Most Popular Question
copying tape
  • Video Cameras
