Have you tried cleaning the laser lense? If not, I would recommend that you do. If you are not tech savvy, I would have a xbox repair service clean and check the laser unit. Good luck!Have you tried cleaning the laser lense? If not, I would recommend that you do. If you are not tech savvy, I would have a xbox repair service clean and check the laser unit. Good luck!
You can't post conmments that contain an email address.
The problem is the lens of your dvd. You will see the optical lens when you open the the dvd and put the disc. Cleaning the lens of the dvd, you must be very careful, never touch the lens with your hand,Use a cotton buds to wipe the the lens gently.
Hi,the most common reason for the Games not reading discs is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your game including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your game going again!
yeah, you can keep opening and closing it till it works or you can send it in to get it repaired. i tried every way possible to fix it, but i couldnt. something in the dvd drive has gone out and won't read discs the same anymore.
your dvd board is going out or your laser is screwed as this as happened to mine before. get it repaired. i have no idea how to fix it without a personal repair. if you had to repair it yourself, i would consider switching out your laser.
