There's a switch activated by you removing it and putting it back in...that switch could be loose or defective...if the Dehumidifier has a Digital screen etc it could be a problem in the circuit board itself . The switch is there to shut off the unit when the pan is full...well the switch would be the first place I look.....and when the unit stops what happens???...the empty tray light comes on ??? It may be possible to install the drawer incorrectly...make sure it sits in properly etc
So I just had this happen with my Frigidaire fad704dwd dehumidifier. I went to basement and heard it running and sounded off. The compressor was running fan was off which is bad and humidity said 30. I then pushed the off button and it stayed running. I was able to fix it. To make long story short it was a bad ground. I took the plastic back, sides, and front off. There was a green ground (main ground) and Green/yellow ground (fan ground) on the front coil with a bunch of rust. Removed the grounds connected them both together and cleaned the surface area and used a new stainless screw nut and screw to remount the wires to evaporator coil. Everything started working fine after that and I put it back together. Good Luck
