Goldstar DH504EL Dehumidifier
Take a brief Survey Take a brief Survey   Add to My Products Add
Problems with Goldstar DH504EL Dehumidifier?
Troubleshooting and Support
Solved Problems for Goldstar DH504EL Dehumidifier RSS Feed Post a New Problem
everything works, but does not collect...
We have had the dehumdifier for a year or so and it worked fine up until a month or so ago. It runs like normal, but no...
6 Solutions
GHD30 dehumidifier completely dead
I have a Goldstar GHD30 dehumidifier approximately 2 years old. It had recently been leaking a blue green fluid like...
1 Solution
goldstar dehumifier #DH404E/GD40E --cannot...
Can I pull the plug on the unit to shut it off, as power button not functioning? Thank you for the help!!
1 Solution
I have a Goldstar GHD30 dehumidifier. I have not used it in awhile. I plugged it in to run it today and it does not...
1 Solution
Humidifier says "bucket full", ...
Humidifier is set for 50%, it is saying bucket full (it is empty) and 1%. Turn power off and it starts up with 50% and...
1 Solution
Gold Star HD504EL Dehumidifier owner's...
We are needing an owner's manual for this dehumidifier. Can anyone tell me where to get one? Thank you! Sue
1 Solution
GoldStar DH504EL Dehumidifier
Can I convert the unit to only use the drain hose instead of the bucket, so I don't have to empty the bucket? It would...
1 Solution
Unsolved Support Problems
Unsolved Problems for Goldstar DH504EL Dehumidifier RSS Feed Post a New Problem
Hanging wire
I took the front panel off to clear.  There is a black wire with prongs on one side and I don't know where it is to...
Post a Solution
GoldStar Dehumidifier GHD30- Auto Shut-off...
GoldStar Dehumidifier GHD30- Auto Shut-off light blinks ????
Post a Solution
my hampton bay dehumidifier power
my hampton bay dehumidifier power button keeps blinking but wont run
Post a Solution
dehumidifier is giving error code
dehumidifier is giving error code CH 01
Post a Solution
Unit will not turn on.
Unit will not turn on. About 1 second after I plug it in, I hear a short 'beep', but the display doesn't light up. The...
Post a Solution
my dehumidifier keeps running even
my dehumidifier keeps running even when I have it turned off, i have to unplug it to get it to stop
Post a Solution
Dehumidifier Not Reducing RH
?My 2 year old dehumidifier does not remove adequate moisture as before.? In response to the above comment...
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Pints per 24 Hrs50 Pints
Bucket Capacity21 Pints
Humidity ControlManual
Technical Features
Drain HoseConnectable
Energy Star RatedYes
Dimensions
Depth13.38 in.
Height21.25 in.
Width15.17 in.
Sponsored Links
Loading problems.
Top Dehumidifier Experts
22yooper
6 solutions
Air Conditioners, Freezers, Dehumidifiers...
Ask Me
Guru
MNTECH
4 solutions
Large Appliances
Ask Me
Guru
Benimur
4 solutions
TV and Video, Computer Hardware, Storage and Media...
Ask Me
Guru
Repair Service
Find Dehumidifier Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
