Please help. I'm trying to take the two fan blades off of the blower motor on a 1992 Honda Accord without destroying them. Anyone have an answer to this? Any help would be much appreciated.
First of all, thanks for all of the help. I ended up taking the whole assembly to a Pep Boys store. They were incredibly nice and helpful. The fan wheels were on the motor mandrels for more than 17 years.
It took quite a lot of work to get both of the wheels off. They used a nail punch and hammer to get the buggers off.
Now I can replace the motor and get back to having heat for the upcoming Chicago winter.
Thanks again for all of your help. Your guys have been great.
There should be a simple retaining clip at the outside of each of those fans(much like the ones that go around small hoses). Take off those clips and slide the plastic fan off the rod. Of course, sometimes such things are not as easy as they sound. If the rod shows rust or grime, you may have to hold the rod with a pair of pliers (in the portion that the fan will not slide over) and turn the plastic fan a few times to break if loose from the rod, then work is slowly off. Some steel wool on the rod before you replace the fan blades might make it easier to put new ones on.
Hope this helps you.
Yes sir, I have removed the heater blower motor for replacement purposes but I am having trouble removing the two plastic fans from the motor mandrels. Any suggestions?
I'd appreciate it.
SORRY NEVER DID THIS ONE
blower motor for the heater/ac?
