SOURCE: MY LG TV PICTURE
You have a vertical issue in the TV itself. It is best to take it in to a servicer.
SOURCE: WARNING LIGHT ON FRONT OF TV
Your Tv requires the lamp hours to be re-set. You will need to acess the Service mode settings via a service remote from your authorised LG service agent.
SOURCE: My LG Dare's screen is
It is possible that the display is faulty . You might have to confirm it with a test on the voltages present to the display, drive or the connection cord.
Remove and reset and if there is no visible change the display can be faulty.
SOURCE: I have a LG washer
FE = Fill Error. Not a faulty water valve in your case. (FE codes if it takes too long to fill the machine, but if the water is leaking out, the valve is not the problem, the leak is) If you take the back cover off, you might be able to see where the water is comming from. Possibly the black rubber hose from the tub to the pump has a leak.
SOURCE: All of a sudden whilst watching TV - a voice now
Turn off the SAP feature (Secondary Audio Program).
