My Visio razor 47 in LED lost its picture and only stays black while power is on. It won't display the inputs or anything on the screen. I have tried powering off and on again, unplugging the tv
    Top Expert:
  • Televison & ... Master
  • 55,370 Answers
It is likely that the internal power supply has failed
Posted on Mar 09, 2013
Anonymous
SOURCE:
Anonymous
SOURCE: Black screen after 5 minutes of use with Fujitsu PDS-420 plasma
most of the time, when the power light stay green, thr filter capacitors in the power supply have lost value, & need replacing.
When the power light turns red it indicates loss of signal. This could be the same problem except the input signal has been lost. Try replacing power supp;y caps , about 4 of them.
Works 90% of the time. Hobby of mine, Art
Posted on Dec 29, 2007
B52Tony
Tony Nguyen
  • 96 Answers
SOURCE: vizio 47" lcd no picture no sound has power
this could be one of two problem. first, check if you have back light. If you do then the problem is with the M/B. Second, if you don't have back light then the inverter is bad and needs to be replace.
Posted on May 20, 2009
Anonymous
  • 1139 Answers
SOURCE: SV470XVT Vizio picture freezes
Hello, This seems more like an interface problem then a board issue. Which interface are you using Component Video, HDMI or , RF(F Connector)? If you are using the RF (F Connector) there might be a problem in the tuner including the RF and IF sections on the circuit board. If you are using HDMI there might be a problem in the HDMI Integrated Circuit If you are using componente video the there might be a problem in the video circuits connected to the RCA jacks of the Component video input. If I were you I would have the take the TV back to the shop and have these items checked out, because board swapping is not the proper thing to do. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Posted on Jun 14, 2009
Anonymous
SOURCE: no picture or sound, light comes on in the front and have to unplug tv to turn it off.
I had this exact problem on my Vizio 47" HDTV. I removed the speakers and all the screws on the back cover. Took the cover off and located the fuses on the largest circuit board. The are in the upper right hand corner of the board. There are 3 of them in a row labeled LF 1.5, LF 3.0 and LF 3.0. The are white in color with copper ends. I took a volt meter and measured continuity across all fuses individually and found the LF 1.5 to be blown. The guy at the electronics store sold me a barrel 1.5A fuse and told me to soldier it across the top of the blown fuse. It took an extra set of hands but the TV works perfectly.
Posted on Jun 23, 2009
Anonymous
  • 92 Answers
SOURCE: westinghouse 30" lcd tv has no sound no picture,but green lighton
Replace the Power Supply.
Posted on Sep 06, 2009
The tv has sound but no picture. For
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
My 32' LG LED TV has suddenly lost picture! The sound is all right but the Screen is pitch black. After switching it on the picture flashes for a second and then the screen goes completely black.
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by Repair.com 472,733 views. 2:30. LG LCD TV REPAIR -NO PICTURE ...
Dec 21, 2015 | LG 47LN5400 47" LED TV 1920x1080, 120 Hz....
I have a Lg LED tv model 47LN5750 that turns on but then stays on the LG "lifes good" screen and will not do anything more. what could be wrong?
Corrupted firmware. A firmware update is necessary. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 13, 2015 | LG 47LN5750 47" LED TV 1920x1080, 120 Hz,...
When turned on, screen goes black, but power light stays green
It sounds that the main digital board to this TV is faulty. Contact any service technician.
Jun 26, 2013 | Sanyo LCD-42CA9S VIZON MULTISYSTEM 42" LCD...
How do i fix a vizio 42" tv with a black screen, no sound
THE MAIN BOARD AV BOARD HAS WENT OUT JUT HAPPENED TO ME TODAY
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/shawn_b2b2e24a98865a53
Feb 28, 2013 | Vizio Razor M421nv 42" 1080p Hd Led Lcd...
I have a 47" Visio 1080p. Tv is always set at hdmi
AV inputs are for standard analog video which is 480i. HDMI and Component inputs are the high definition inputs that run at either 1080i or 1080p You won't ever get 1080i or p through AV inputs.
Oct 22, 2012 | Televison & Video
When i power up my 47 inch flatscreen the power comes on for a second with the picture than shuts off
With most televisions there are two options why you won't get any image on your screen:
1) You are using cable and haven't chosen a channel yet, try using the power button, and immediatly chose a number of which you know is a chanel.
2) You are using a DVDplayer, Digital television, ... and your tv is still connected to the cable or another input. Look for a button on your remote that is shaped like a square with an arrow pointing in it from the side, hit this button to swap between input channels to find the right input.
Aug 22, 2012 | Televison & Video
Visio light on front flashes on and off tv won't come on
Unplug your TV and then plug it back in, let it flash on and off without doing anything for 5 minutes or so and then turn it on. It does it once amonth or so for some reason.
Nov 24, 2011 | Vizio XVT3D474SV 47 in. 3D LCD TV
Screen stays either black or white
Replace the entire DAC board (board with power suplly going into it) for easiest solution.
Aug 19, 2009 | ViewSonic VA703mb Monitor
Visio LCD TV - Partial Picture blacked.
Hello! I have a 32" Vizio LCD...within 30 minutes of the tv being turned on, black lines start running through the bottom half of the screen and eventually blacking out the bottom half of the tv screen. It also doesn't have anything to do with the ratio as I have tried that. HELP!
Jan 06, 2009 | Toshiba 42HP66 42 in. LCD Television
Sorry to inform you my freind, but the main board has to be replaced in this beast. Could get expensive. there are no schematics and or componets listed to repair this module. Its a board level repair only. Try going to ptscorp.com, find their phone number, and see if they repair these boards. if not you will need to contact the manufacturer for replacement boards. good Luck Please do not forget to rate this thread.,
Dec 15, 2006 | Fujitsu Plasmavision PDS-4209 42 in....
Televison & Video Logo
190 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
