Usually the tension of the take-up reel keeps the shut-off arm taught and everything works. If the shut off arm falls down, the recorder stops. Is that what's happening?
Inadaquate (or NO) take-up tension can cause this; so can WARPED take up reels. Another possibility: if you play a lot of old tapes, the groove in the shut-off arm collects dirt and oxide, so the tape - as it goes through it - jams, and the take-up reel can not overcome the tension. The arm "falls down" and shuts off the machine. Also SOME tapes (which were "cut down" from 2"
tapes) are poorly ****, and will jam some machines.
This is what I do for a living, so if these suggestions don't work, give me more information, and I'll solve your problem.
My Marantz CP430 will only playback if you press ''pause'' then ''play'' then release ''pause''....
(More)
My Marantz CP430 will only playback if you press ''pause'' then ''play'' then release ''pause''. Surely this can't be right? Otherwise all functions like new. Don't want to sell to someone if this is a major problem. Thanks, Nik
Pioneer CTF8282 , runs and plays for a few seconds and then clicks off , not the power just the...
(More)
Pioneer CTF8282 , runs and plays for a few seconds and then clicks off , not the power just the running . FFW for a few seconds and then clicks off . Switched tapes , do not believe it is because of casette .
I have an old 1973 Roland RE200 Space Echo (NOT the later more popular RE201) it has a DC Servo...
(More)
I have an old 1973 Roland RE200 Space Echo (NOT the later more popular RE201) it has a DC Servo motor to drive the tape capstan, and there is noise breaking through onto the audio signal path. I have replaced the PSU caps and the smaller Lytic caps across the output feed to the motor and this has helped but not cured it, please can anyone offer any advice, I do not have a circuit and I dont think there is one available as this was a Japanese only market unit, not UK export. I have also replaced a couple of 2SC828 transistors that are on the drive outputs to the motor, and there is a larger 2SD234 mounted on a heatsink that also has something to do with the motor drive, but I dont have a replacement one of these, I do have a TIP142 though that appears to meet all the spec and more, any help is greatly appreciated. cheers Paul
