20 Most Recent Tascam 2488 Portastudio Multitrack Recorder System Questions & Answers
I had the same issue on my 2488neo. What I found that worked for me, was during the mixdown, make sure the solid levels on the right side of the mini screen are at the top of the black line, don't worry about it sounding too loud. After your mix down is done, pick a mastering tool that best fits your style of music, during this process any levels that go over peek will be eliminated. Once your mastering is done, burn a CD, but don't finalize the CD, so you can use it again to keep checking if the volume does not match that of a regular CD (a known band CD from the store) this worked for me, hopefully it will for you as well..
Tascam 2488... | Answered on Feb 14, 2019
You assign the effects basically the exact same way you assigned the channels to inputs, except you press and hold the "MICX4" button and press the "Select" key to the channel (or channels) you want to assign the effects to. Once you assign the effects to the channel, you can edit to the effect you want, and edit the values of the effect.
Good Luck!
Tascam 2488... | Answered on Dec 10, 2018
I think if you had the manual you would know the answer to the last question.
Tracks must be a minimum of 4 seconds long (page 118)
Register and download the manual for free at audio.manualsonline.com
Search for "Tascam Portastudio 2488"
http://music.manualsonline.com/manuals/mfg/tascam/2488neo.html
Tascam 2488... | Answered on Mar 12, 2018
You should be able to view the file on a computer. Select the file and delete it. Presumably there was an error after the file was recorded and all you probably have is the file name and a shell of a file. Hence it being only 30K.
There is nothing you can do with the file. And whatever you recorded was lost.
A 40 minute wave file would be massive. Try recording as MP3 for long files. You might be OK at 3 to 6 minutes with a WAV file.
Tascam 2488... | Answered on Mar 02, 2018
If it has identical wiring and voltage, yes. Fleabay will have one.
eBayeBay
Tascam 2488... | Answered on Aug 07, 2017
Turning the power off with out going through the shut-down process will sometimes trash the hard drive making it un readable. To force format of hard drive hold down the shut down, send, shift and quick routing keys at the same time then turn power on. This will format the HD. When finished the display will show "Factory initalize complete" "please power off" NOTE you will lose every thing on the HD including the demo song.
Tascam 2488... | Answered on Sep 25, 2016
Tascam has a great website with FAQs and manuals links.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
Tascam 2488... | Answered on Apr 02, 2016
I guess this is what you need
View Tascam 2488 PDF User Manual Online
If you have any question about your home appliances you can always check manualbirds.com for free manuals and guides.
Tascam 2488... | Answered on Nov 03, 2015
adjust your top knob which is called the gain, this will allow the incoming signal to be muchlouder depending on where you set it , the bottom fader is for playback volume and mixing and you should also a avolume control for your head set , follow also the recording instructions in your manual for optimal settings , there,s no reason that your recordings should come out with low volume other then your gain control being set to low , hope i was able to help , if i was please leave a nice rating ,sincerely glenn mayer
Tascam 2488... | Answered on Aug 03, 2015
When I record on DP-02/CF Tascam I can't get the music to play back. Do I have to do something other than rewind to be able to hear it? Albert S.
I just had the same problem with my Tascam recorder. Did you ever find a solution? I really don't want to lose all the work I've done
Tascam 2488 Portastudio Multitrack Recorder System Logo
342 questions posted
Top Tascam Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Tascam Audio Players & Recorders
Most Popular Question
start auto repair program
  • Audio Players & Recorders
