Microsoft Xbox 360 Console Logo
Posted on Dec 30, 2007
Xbox 360 turn power on button,button light up in the middle,controllers guide buttons light up four green light.
A
Anonymous
Did you program the controller to the system?
Controller doesnt turn on but batterys are good
Connect a game controller
Solutions
Learn how to connect a wireless or wired controller to your Xbox 360 console.
Connect a wireless Xbox controller
  1. Turn on your console.
  2. Press and hold the Guide button on the controller until the controller turns on.
  1. Press and release the connect button on the console.
Xbox 360 E console fbbfb609-f7ed-4e6e-bd35-7543b1c20d61.png?n=xbox360-connect-m-s.png Xbox 360 S console Original Xbox 360 console 342c6e70-9e56-43d8-bb3a-05f5411040bd.png?v=1#xbox360s-connect-m-m.png 170df81e-0a79-49be-8236-a0fb68eec37b.png?v=1#xbox360-connect-m-m.png
  1. Within 20 seconds, press and release the connect button on the controller.
  1. When the lights surrounding the power button on the console stop flashing, the controller is connected.
On the Xbox 360 S console, each connected controller is assigned to one of four positions. Each position corresponds to a lighted section around the console power button and the controller Guide button. On the 360 E console, a solid green light on the front of the console indicates that the controller is connected. To determine the player position associated with your accessory, look at the ring of light that surrounds the Guide button on the controller.
c9341988-8ed5-4217-9b87-353de50efbec.png?v=1#connect-xbox-controller-m-m.png 5e4ab6ab-8cb0-41e6-a037-b88221a430c7.png?n=connect-xbox-controller-360-m-s.png
71add0b7-ddf2-4439-b4b4-f50f156d92b7.png?v=1#controller-batteries-m-m.png If the controller does not turn on, check the batteries. Insert fresh AA batteries, making sure they are correctly positioned in the battery case.
You can also use the Xbox 360 Play & Charge Kit or the Xbox 360 Quick Charge Kit to power the controller. Learn more about Xbox controllers and chargers.
To connect additional controllers, follow these same steps again. You can connect up to four controllers to the console. Each connected controller is assigned a position that corresponds with the lighted sections that appear around the console's power button and around the Guide button located in the middle of each controller.
  • To disconnect a wireless controller, press and hold the Guide button for three seconds, and then choose to turn the controller off.
  • When you turn off the console, the controller will reconnect the next time you turn on the console.
  • The controller can be connected to only one console at a time. You can connect the controller to a different console, but the connection to the previously connected console will be lost.
My controller was working one day and then stop working the next day it had fresh battery
Solutions
Ho w to fix x box from controller to x box is really slow how to make it normal
Connect a wired Xbox controller
5fb17f50-7448-45d5-a294-9ea90994f55b.png?v=1#controller-wired-m-m.png Plug the Xbox 360 Wired Controller into a USB port on the Xbox 360 console. There are two USB ports on the front of the console. To disconnect the controller, pull on the connector, not the cable.
cbe46bf0-3a46-4d53-9d8c-6697aa57622a.png?v=1#controller-cable-release-m-m.png The cable on the Xbox 360 Wired Controller has an inline release. The inline release on the controller cable is a safety feature designed to reduce the chance of the Xbox 360 console falling if the cable is pulled.
Wireless controller troubleshooting
If your wireless controller disconnects or cannot connect to your console, see Xbox 360 Wireless Controller disconnects or can't connect.
If your wireless controller does not turn on or loses power, try the following solutions:
Solution 1: Replace the batteries
Insert a new set of AA alkaline batteries into the Xbox 360 Wireless Controller, and then try to turn it on.
Solution 2: Try a different battery pack
If you have another Xbox 360 Wireless Controller, take the battery pack off that controller and attach it to your controller. Then try to turn your controller on.
If your controller works with the different battery pack, your original battery pack might be defective. If your controller is under warranty, you can order a replacement battery pack from Xbox Support . See the Assistance section at the bottom of this page for more information.
If your controller is out of warranty, you can buy a new battery pack from a retail store.
Solution 3: Try a rechargeable battery packIf you or a friend has an Xbox 360 Rechargeable Battery Pack, attach that battery pack to your controller and try to use your controller. If your controller works with the rechargeable battery pack attached, you can buy a new battery pack from a retail store or order a replacement battery pack from Xbox Support. See the Assistance section at the bottom of this page for more information.
How to connect wireless controller to my console
  3. Press and release the connect button on the console.
    360s_bindbtnhand.jpg consoleconnectbtn.jpg Xbox 360 S console Original Xbox 360 console
  4. Within 20 seconds, press and release the connect button on the controller.
  5. When the lights surrounding the power button on the console stop flashing, the controller is connected.
Each connected controller is assigned to one of four positions. Each position corresponds to a lighted section around the console power button and the controller Guide button.
5helpful
4answers
My xbox 360 wireless controller will not connect to my xbox 360 console even when i press the button that scans for the pad but it still turns on the xbox 360 when you press the middle button on the pad
Turn off both the console and the controller, then follow these steps:
  1. Turn on both the Xbox 360 Wireless Controller and the Xbox 360 console.
  2. On the console, press the connect button. (to the immediate right of the memory card slot on the console)
  3. On the controller, press the connect button. (Look on top of the controller for a small button.)
  4. The green lights that surround the Guide button on the controller and the power button on the console spin and flash when the controller is being connected to the console. After the controller is connected, a single green light illuminates on the controller and on the console to show you which quadrant the controller is connected to.
11helpful
7answers
How do you turn on an xbox 360?
Simply press the big button that has green lights around in front of your console
1helpful
Controller wont hook up with console ?
Is this a new controller?
Are the batteries new/recharged?
This is the sequence summary on where you are going to focus:
Step 1 - Controller
Step 2 - Console
Step 3 - Console
Step 4 - Controller
Step 5 - Both
Assuming your controller is a wireless version, Lets start!
Step 1 | Press and hold the Xbox Guide button until the controller turns on. The Xbox Guide button is the round button with the green "X" near the center of the controller.
Step 2 | Make sure that your Xbox 360 console is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console.
Step 3 | On the Xbox 360 console, press and release the Connect button. The Connect button is the small round button on the Xbox 360 console.
Step 4 | On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the left bumper button and the charging port.
Step 5 | After the Ring of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
Light indicator on console
Green light in the center- power is on
Green light on one quadrant - controller is connected
Four green lights rotating on four quadrants - ready to connect with controller
Light indicator on wireless controllers
No lights - no batteries
Green steady light on one quadrant - connected
Blinking green lights - its either its ready to connect or the batteries are dying
*Make sure that you have a fully recharged rechargeable batteries
*Make sure that you have a functioning/new non-rechargeable batteries
*If the steps above aren't working use another Xbox360 controller and follow the same steps.
If the new/working controller is connecting with the console this means that the previous controller is faulty - needs replacement.
If the new/working controller is not connecting with the console this may mean that the console is faulty - needs repair.
*NEVER TAMPER WITH ANY OF THE TWO AS TAMPERING WILL VOID EXISTING WARRANTY.
5helpful
My controller and xbox wont connect
To connect the controller to your Xbox 360 console, follow these steps:
  1. Press and hold the Xbox Guide button until the controller turns on. The Xbox Guide button is the round button with the green "X" near the center of the controller.
  2. Make sure that your Xbox 360 console is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console.
  3. On the Xbox 360 console, press and release the Connect button. The Connect button is the small round button on the Xbox 360 console.
  4. On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the left bumper button and the charging port.
  5. After the Ring of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
2answers
My xbox 360 and wireless controller will sync but then it wont show that they are connected and even though i turned on my console by using the button on the console it just shows the green light turn on...
  2. Make sure that your Xbox 360 console2_bing.gif is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console2_bing.gif.
  5. After the Ring2_bing.gif of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
Setting up a 360 wireless controller
Turn Your Console and Controller On The Xbox® Guide button in the center of your controller puts the Xbox 360® experience at your fingertips. Press and hold the Xbox Guide button to turn your console on.
To turn on your console only, press the power button on your console. To turn on your controller only, press the Start button on your controller.
Once on, pressing the Xbox Guide button gives you immediate access to the Xbox Guide. To turn off your console, press and hold the Xbox Guide button for three seconds and then confirm your selection.
Turn Your Console and Controller Off To turn your console and controller off, press and hold the Xbox Guide button on your controller for three seconds. Then select whether you want to turn off just your controller or both your controller and your console. (Selecting the console will turn off both the console and all connected controllers.)
To turn off one controller when multiple wireless controllers are connected, press and hold for three seconds the Xbox Guide button of the controller you want to turn off, then select Turn Off Controller.
To turn off your console only, press the power button on your console
When you connect a controller to your console, it is assigned a specific quadrant, which glows green to indicate the controller's number and position. Each subsequent controller connected to the console (up to four) is assigned an additional quadrant.
If system problems should arise, the Ring of Light on the console will flash combinations of red.
I hope this solved your problem.
Happy Gaming!
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
