Question about Microsoft Xbox 360 Controller
My xbox 360 wireless controller will not connect to my xbox 360 console even when i press the button that scans for the pad but it still turns on the xbox 360 when you press the middle button on the pad
    New Friend:
  • 13 Answers
Turn off both the console and the controller, then follow these steps:
  1. Turn on both the Xbox 360 Wireless Controller and the Xbox 360 console.
  2. On the console, press the connect button. (to the immediate right of the memory card slot on the console)
  3. On the controller, press the connect button. (Look on top of the controller for a small button.)
  4. The green lights that surround the Guide button on the controller and the power button on the console spin and flash when the controller is being connected to the console. After the controller is connected, a single green light illuminates on the controller and on the console to show you which quadrant the controller is connected to.
Posted on Feb 28, 2011
    New Friend:
  • 25 Answers
Could be a couple of things.
Replace the batteries, making sure they are in the controller in the right direction.
Resync the controller to your xbox. This is done by pressing the small sync button on the front of the xbox, then pressing the small sync button on the top of the controller (near the charge port.)
If neither of these work, you might have a faulty controller.
    New Friend:
  • 40 Answers
Hold both sync buttons for at least 2 seconds.
Posted on Jul 29, 2011
    New Friend:
  • 23 Answers
6ya staff
SOURCE:
Controller doesnt turn on but batterys are good
Connect a game controller
Solutions
Learn how to connect a wireless or wired controller to your Xbox 360 console.
Connect a wireless Xbox controller
  1. Turn on your console.
  2. Press and hold the Guide button on the controller until the controller turns on.
  1. Press and release the connect button on the console.
Xbox 360 E console fbbfb609-f7ed-4e6e-bd35-7543b1c20d61.png?n=xbox360-connect-m-s.png Xbox 360 S console Original Xbox 360 console 342c6e70-9e56-43d8-bb3a-05f5411040bd.png?v=1#xbox360s-connect-m-m.png 170df81e-0a79-49be-8236-a0fb68eec37b.png?v=1#xbox360-connect-m-m.png
  1. Within 20 seconds, press and release the connect button on the controller.
  1. When the lights surrounding the power button on the console stop flashing, the controller is connected.
On the Xbox 360 S console, each connected controller is assigned to one of four positions. Each position corresponds to a lighted section around the console power button and the controller Guide button. On the 360 E console, a solid green light on the front of the console indicates that the controller is connected. To determine the player position associated with your accessory, look at the ring of light that surrounds the Guide button on the controller.
c9341988-8ed5-4217-9b87-353de50efbec.png?v=1#connect-xbox-controller-m-m.png 5e4ab6ab-8cb0-41e6-a037-b88221a430c7.png?n=connect-xbox-controller-360-m-s.png
71add0b7-ddf2-4439-b4b4-f50f156d92b7.png?v=1#controller-batteries-m-m.png If the controller does not turn on, check the batteries. Insert fresh AA batteries, making sure they are correctly positioned in the battery case.
You can also use the Xbox 360 Play & Charge Kit or the Xbox 360 Quick Charge Kit to power the controller. Learn more about Xbox controllers and chargers.
To connect additional controllers, follow these same steps again. You can connect up to four controllers to the console. Each connected controller is assigned a position that corresponds with the lighted sections that appear around the console's power button and around the Guide button located in the middle of each controller.
  • To disconnect a wireless controller, press and hold the Guide button for three seconds, and then choose to turn the controller off.
  • When you turn off the console, the controller will reconnect the next time you turn on the console.
  • The controller can be connected to only one console at a time. You can connect the controller to a different console, but the connection to the previously connected console will be lost.
Oct 11, 2013 | Microsoft Xbox 360 Controller
My controller was working one day and then stop working the next day it had fresh battery
Solutions
Jul 31, 2013 | Microsoft Xbox 360 Controller
Ho w to fix x box from controller to x box is really slow how to make it normal
Connect a wired Xbox controller
5fb17f50-7448-45d5-a294-9ea90994f55b.png?v=1#controller-wired-m-m.png Plug the Xbox 360 Wired Controller into a USB port on the Xbox 360 console. There are two USB ports on the front of the console. To disconnect the controller, pull on the connector, not the cable.
cbe46bf0-3a46-4d53-9d8c-6697aa57622a.png?v=1#controller-cable-release-m-m.png The cable on the Xbox 360 Wired Controller has an inline release. The inline release on the controller cable is a safety feature designed to reduce the chance of the Xbox 360 console falling if the cable is pulled.
Wireless controller troubleshooting
If your wireless controller disconnects or cannot connect to your console, see Xbox 360 Wireless Controller disconnects or can't connect.
If your wireless controller does not turn on or loses power, try the following solutions:
Solution 1: Replace the batteries
Insert a new set of AA alkaline batteries into the Xbox 360 Wireless Controller, and then try to turn it on.
Solution 2: Try a different battery pack
If you have another Xbox 360 Wireless Controller, take the battery pack off that controller and attach it to your controller. Then try to turn your controller on.
If your controller works with the different battery pack, your original battery pack might be defective. If your controller is under warranty, you can order a replacement battery pack from Xbox Support . See the Assistance section at the bottom of this page for more information.
If your controller is out of warranty, you can buy a new battery pack from a retail store.
Solution 3: Try a rechargeable battery packIf you or a friend has an Xbox 360 Rechargeable Battery Pack, attach that battery pack to your controller and try to use your controller. If your controller works with the rechargeable battery pack attached, you can buy a new battery pack from a retail store or order a replacement battery pack from Xbox Support. See the Assistance section at the bottom of this page for more information.
Feb 08, 2013 | Microsoft Xbox 360 Controller
Xbox 360 controller not working, all 4 lights are blinking.
The wired and wireless controllers can be actively connected to an Xbox 360 console all at one time. Each connected controller is assigned a quadrant on the Ring of Light. Before you can connect a wireless controller, at least one quadrant must be free and will be unlit.
Connecting an Xbox 360 Wireless Controller to an Xbox 360 Console is called Connecting. To connect a controller to a console:
First, Press and hold down the Guide Button on the wireless controller until it turns on.
Second, Press and release the power button to turn the console on.
Third, Press and release the connect button on the console.
Fourth, Press and release the connect button on the controller.
Fifth, After the ring of light on the controller and console spin and flash once, the controller is connected. The quadrant that remains lit indicates the controller's position.
Four Green lights on the controller's Ring of Light flash continuously
The Please Reconnect Controller message appears on the monitor
There is interference and the controller does not respond properly
Step 1: Ensure that either the AA batteries are new or the Xbox 360 Rechargeable Battery Pack has a full charge.
Step 2: Ensure that you have performed the proper procedure to connect the Xbox 360 Wireless Controller to the console.
Step 3: If still experiencing issues, ensure there is a clear line of sight between the front of the console and the wireless controller. If there are any obstructions, especially metal objects, remove them.
Step 4: 2.4 gigahertz cordless telephones, microwave ovens, and Bluetooth headsets for cell phones can interfere with the operation of the wireless controller. Turn off or unplug those devices and then try to connect the wireless controller to the console again.
Step 5: If these steps did not resolve the issue, the wireless controller may need to be replaced.
Jun 06, 2010 | Microsoft Xbox 360 Controller
How do you turn on an xbox 360?
Simply press the big button that has green lights around in front of your console
Apr 21, 2010 | Microsoft Xbox 360 Console
How to setup two wireless controlers to an xbox
  1. Press and hold the Xbox Guide button until the controller turns on. The Xbox Guide button is the round button with the green "X" near the center of the controller.
  2. Make sure that your Xbox 360 console is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console.
  3. On the Xbox 360 console, press and release the Connect button. The Connect button is the small round button on the Xbox 360 console.
  4. On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the left bumper button and the charging port.
  5. After the Ring of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
  6. Note If you want help connecting an Xbox 360 Wireless Controller to your Xbox 360 console, you can contact Xbox Customer Support. For more information about how to contact Xbox Customer Support, please visit the Xbox Support (http://www.xbox.com/support/) Web site.
  • The controller remains connected to the Xbox console even when you turn off the Xbox console.
  • The controller is connected to only one Xbox console at a time. You can connect the controller to a different Xbox console at any time, but your connection to the previously connected console is lost. You must repeat these steps to reconnect the controller to the original console after your connection to the console is lost.
  • The controller works within 33 feet (10 meters) of your Xbox 360 console. However, objects between the controller and the console may reduce this range.
  • If the controller does not turn on, the batteries may have to be replaced.
Mar 22, 2010 | Microsoft Xbox 360 Console
My controller and xbox wont connect
To connect the controller to your Xbox 360 console, follow these steps:
Aug 28, 2009 | Microsoft Xbox 360 Wireless Controller
My xbox 360 and wireless controller will sync but then it wont show that they are connected and even though i turned on my console by using the button on the console it just shows the green light turn on...
  2. Make sure that your Xbox 360 console2_bing.gif is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console2_bing.gif.
  5. After the Ring2_bing.gif of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
Aug 15, 2009 | Microsoft Xbox 360 Console
Xbox 360 wireless controller not connecting.
it sounds like your controller keeps losing sync with the 360.
- turn them both off
- turn on the 360 with the power button on the console
- wait for it to start up, then press the sync button next to the usb flap on front.
- then press the sync button on the controller (by the recharge connection slot)
That should reset it.
Nov 13, 2008 | Microsoft Xbox 360 Wireless Controller
Setting up a 360 wireless controller
Turn Your Console and Controller On The Xbox® Guide button in the center of your controller puts the Xbox 360® experience at your fingertips. Press and hold the Xbox Guide button to turn your console on.
To turn on your console only, press the power button on your console. To turn on your controller only, press the Start button on your controller.
Once on, pressing the Xbox Guide button gives you immediate access to the Xbox Guide. To turn off your console, press and hold the Xbox Guide button for three seconds and then confirm your selection.
Turn Your Console and Controller Off To turn your console and controller off, press and hold the Xbox Guide button on your controller for three seconds. Then select whether you want to turn off just your controller or both your controller and your console. (Selecting the console will turn off both the console and all connected controllers.)
To turn off one controller when multiple wireless controllers are connected, press and hold for three seconds the Xbox Guide button of the controller you want to turn off, then select Turn Off Controller.
To turn off your console only, press the power button on your console
When you connect a controller to your console, it is assigned a specific quadrant, which glows green to indicate the controller's number and position. Each subsequent controller connected to the console (up to four) is assigned an additional quadrant.
If system problems should arise, the Ring of Light on the console will flash combinations of red.
I hope this solved your problem.
Happy Gaming!
Oct 17, 2008 | Microsoft Xbox 360 Wireless Controller
Microsoft Xbox 360 Controller Logo
1,060 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
