Front end noise when turning. almost sounds like metal to metal.
There are a couple of things to cause metallic sounds when turning. First thing, is if it's a clicking sound when you turn, then you have a cv joint going bad. It's usually more prominent when moving in reverse, however it can happen just as well while moving forewards. Secondly, if it's more of a grinding or scraping noise, we have a couple of options. The sound could be coming from the brakes, if they're worn or have grit stuck in them, or it could be bad bearings in the front wheel hub. The wheel hub has a tendency to making a whining noise when driving; usually most easily heard when driving past buildings. They can also allow the tire/wheel to present the appearance of leaning when looking at it. If bad enough, it can even rub on the brake caliper, or cause the disc brake rotor to wear out the brake pads prematurely. So, to recap:
Check:
CV joints, if a clicking sound
brakes or wheel hub bearings if grinding or whining sound.
Front end noise clacking sound
