Your source has to be in HD like a local broadcast TV station currently broadcasting in HD which you get with a VHF/UHF antenna connected to the HDTV. Most primetime TV shows are in HD so using the antenna on the HDTV is all you need. Press MENU on your TV remote and make sure you have ANTENNA set instead of cable to get local TV stations.
You also could use your local cable TV provider. You would need digital cable service and a HD cable box with HDMI or component video cable hookup to the HDTV. HD channels are typically above 100. Call your cable TV provider for more details.
Read your user manual for the LG TV. Ask for help from family, friends, neighbors, local electronics shops.
go to the calls setting then find calls recive option and turn it to recive from all i think it is seted on recive only from contacts if not solve then tell me again.thats it
take out memory card and attach to your computer via usb cord and in my computer right click on relevant icon and click format and this should put it back to normal worked for us!!!!!
make sure the wireless part of the router is working fine by trying a computer to connect wirelessly to the router. if it connected fine then it is a matter of matching the wireless settings of the router and the xbox in order for them to synchronize properly.
ok im not sure i understand your question but when your phone is on and you recive a call and you talk to the person and then hang up u get a recived call if your phone is off you wont get a recived call because u did not anser any calls because the phone was off.. and if u have it divirted the phone wont show that it was a recived call
Either calls are blocked in the menu, or the phone has been registered as stolen. If the phone has been blacklisted, the only way to undo this is to phone the original service provider and prove you are the original owner.
Call Up Your Call Centre And Ask For The Service Centre Code
If You Go Into Text Messages And Settings Then Go Into Texts And Cheak Out Service Centre Code And Pop In Right One.
I Recently Had The Same Problem As I Accidently Deleted One OF The Code Numbers Hope This Helped :)
dish network does not "zap" recievers. if you have a pirated system such as a rom 102 card you will need to purchase a new card from a local pirater or online , they run a bout 50 bucks. You should definelty consider calling dish and staring up an ligitimate account if piracy is the case. in order to avoid futre issues.
