Samsung HT-X50 System Logo
Posted on Dec 24, 2007
HT-X50 I have the surroud sond hooked up and it works only with DVDs I need help getting to go through my TV when watching cable and my XBOX 360 I need to know what cables I need and just what to do to get it to function
Anonymous
Level 1:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Dec 26, 2007
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
3962
Points
11
You need an Optical AudioHT-X50 - 1.gif Cable. Hook one end to the HD Cable Box and the other to your Surround Sound System. If you dont have an Optical Cable to your Cable Box, then try using the usual audio cables. But, I have HD and it worked with the Optical Audio Cable.
1helpful
Samsung HT-X50. I just installed a new 50" plasma TV and cabled the digital out to the Samsung HT-X50 digital in via an optical cable. The TV audio is now heard through the HT-X50 speakers but only...
Look into the TV's audio controls. If it was my setup, I'd NOT send audio through the TV to the hifi, nor video through the hifi to the TV. Additional hops and interconnects cause problems even though they're theoretically transparent.
3answers
How do I hook up my new HT-X50 home theater system to my Verizon HD "Motorola" cable box that my sony wega hd tv is hooked up to, so I can get tv shows and dvds to work with my home theater...
Hi evilfan,
If I may add to the postings of Ekse and TampaNative......
Depending on what available cables and connectors that you may have the basic idea is from the cable company in to your Motorola receiver then to your Samsung HT-X50 then to the Sony Wega as below image shows. All other additional devices such as another DVD player or an iPod Nano with Video Dock or anything else would have to be connected to the Samsung.
All external devices would have to be plug in the the different INPUTs as you may decide which is to which. What is important to remember is that everything goes through the Samsung be it incoming or outputs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
2helpful
3answers
Samsung HT-X50 DVD Audio Problem
I had this same problem and checked all of my cables and wires. Come to find out one of the wires that connected to the central audio speaker (the one that the audio track comes from) was unplugged. I plugged it in and that fixed it! My audio track is back! So make sure that all of the speaker cables are properly connected! That might be the source of your troubles!
Picture HT-X50
This problem to the system e.g; ( PAL,SECAM,NTSC....etc)
First check that you tv should be multi-system (not too old model) if it has supported system then turn on the required system manually.
Secondly Check the settings of your Home theater system and change the system accordingly.
Thanks.
1helpful
3answers
Connecting a Samsung HT-Z310 home cinema to a Series 5 Samsung TV and Games consoles, will only work with DVD currently. How do I get the cinema system to work for TV and consoles?
Do you have an Optical Audio cable going from the A/V receiver to the TV? If not, you need to get one. Since the HT-Z310 only has HDMI output and no input there is not audio bypass. Once you connect an Optical Audio cable from the receiver to the TV, anything that goes through the TV (cable audio, PS3 or Xbox 360, DVDs, Radio) will go through the receiver, too.
No Surround Sound While Watching TV
You need a digital audio cable running back from your TV to the HT unit.
2answers
Hooking up a console
well i would run it throw direct to tv ok then digital out from tv back down to this digital inn ok of samsung use hdmi to hd tv fro xbod 20 tims better looking
5helpful
4answers
I have a Samsung HT-X50 Surround Sound, a LG 50" Plasma 50PC5D TV, and DISH Network Satellite.
How can I get surround sound to work on my tv. When I pull up my menu and go to audio the SRS Trusurround XT is not in bold so I cant figure how to connect it so I can have the surround sound coming from the system and not from the tv. Please help.
Hooking up cable through ht-x50
You need an Optical Audio Cable. Hook one end to the HD Cable Box and the other to your Surround Sound System. If you dont have an Optical Cable to your Cable Box, then try using the usual audio cables. But, I have HD and it worked with the Optical Audio Cable.
1helpful
No color on tv when xbox on
Try hooking the xbox up to another tv to see if you get color. If you do it isn't your xbox. If you dont then it's your video cables going bad. Hook a dvd player into the same spot you had the 360 in on your LCD see if you get color. If you dont then its your TV, if you do then it's your xbox video cables going bad.
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
