This is more than likely your laser that is dead and its possibly a
Samsung or Hitachi drive, be careful when
buying a new laser because there is a lot of dodgy ones around at the
minute which can damage your machine or
at the very least will be inferior and not last long.
if your 360 reads DVD's but not games it may be repairable but if it wont
read anything then your better off replacing the laser. strip down the
console and strip the DVD drive, take out the laser and look underneath
it, it will have a code such as HD57 or something else, note that down.
Visit ebay and search for the laser with the same code, buy it, fit it in
and make sure you de-solder the static blob of solder before using it
(search the net about this or ask the seller) and then try your machine
again :)
Linda
xboxrepairkit
PS3 Not Reading Games
If you have this problem it is because
the laser has shifted from where it needs to be and the good news is
that it is not that hard to fix all you need is a good repair guide.
You can of course send it in but the
disc reading issue you should be able to fix in less than 1 hour from
home.
Check out this link for a full
explanation:
besides games have you tried with a dvd movie or Audio CD ???.
